Old 07-16-2021, 08:33 AM   #281
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
If you can't get A052's, then get the Nankang CR-1's, they are closer to the yoks then RE71's (which aren't even made anymore)
Breezio is offline   Reply With Quote
Old 07-16-2021, 10:00 AM   #282
Autoxer62
Originally Posted by Roadphantom View Post
Does anyone know approximately how much a time gap there is between RE71R and A052 on an STX twin on a 60 sec course? I am wondering in case there is no A052 stock available.
The other alternative right now is the Falken RT660. The word I get is they are pretty close to the RE71 for time, and the price is low enough to consider them if your balance between budget and competitiveness leans towards the budget side. That's what I'm running for now as the car isn't very developed anyway (we won't even talk about the sketchy driver )
--Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 07-16-2021, 12:14 PM   #283
MX-5RACER
MX-5RACER's Avatar
Drives: 2018 FA24 SWAP BRZ "ANNIE"
What is the consensus on the Koni/Ground Control coil-overs? I have run them on multiple Miata's and love them. I am looking to replace my FEAL 441+ coil overs as the bearing in the camber plate is making some noise and they just have always felt under-dampened (Especially on rebound).
I was thinking about trying this combo, but with a similar spring rate as my current set-up, with the Race-valving and double adjustables.
https://groundcontrolstore.com/colle...nt=36342399939
DJ
2008 MX-5 PRHT "Violet"
2018 FA24 Swap BRZ "Annie"
MX-5RACER is offline   Reply With Quote
Old 07-16-2021, 06:32 PM   #284
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1 get used to falkens if you can't get yokes, Bridgestone are doa.
Mx5 racer, imho copy someone who's fast and friendly in your region if possible, doing something less then ordinary only works out if you've got a consistent test n tune course and plenty of time available to hone in on what works with that setup.
ineedyourdiddly
Old 07-19-2021, 09:41 PM   #285
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I'll vote here for the Nankang as an alternative. I've been using them to save my precious Yokohama's and they are fine, but of course more expensive than the Falken. If cost is a factor, go Falken.
Kelse92 is offline   Reply With Quote
Old 07-19-2021, 11:27 PM   #286
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
+1 on the Falkens. Since the Yoko's were nowhere to be found, I went with a set of 660's for this season. Really enjoying them so far and have found them to perform better than expected. Only downsize is the weight, but I think it's negligible in reality. They're also much quieter than the 71R's which is nice while on the streets.
smg1138 is offline   Reply With Quote
Old 07-21-2021, 08:54 AM   #287
MX-5RACER
MX-5RACER's Avatar
I appreciate the reply, but I am not looking to copy a set-up. I helped install parts and set-up Teddie's BRZ (2019 National Championship winning car), so I have experience with fast set-ups, including my current FEAL 441+ set-up. I am really looking for any insight anyone may have on the Koni/GC set-up specifically.
DJ
Old 07-21-2021, 09:28 AM   #288
steverife
Drives: 2016 Scion FRS
If you don't want to copy anyone's set up, the Koni/GC setup seems to be the way to go. I searched and couldn't find a word about them.
steverife is offline   Reply With Quote
Old 07-21-2021, 09:37 AM   #289
Kelse92
At the track
Well, I wasn't really a fan of the Koni's that are part of the SSC kit, but I think the combo could be decent for the price. But at the same token, wouldn't it be easier to just do some Bilsteins that are easier to revalve and have them setup to your liking? Which the price point of the Bilsteins its probably a wash. I understand finding a Koni rebuilder is getting a bit difficult these days.
I'm in uncharted territory over here with my Nitrons that just arrived so I understand the not wanting to necessarily copy anyone's setup, but there are of course growing pains and challenges to that...
Old 07-21-2021, 10:40 AM   #290
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Approximate tire hierarchy:
Yokohama (backordered)
Nankang
Falken
Bridgestone/BFG (conditions/surface dependent)
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 07-21-2021, 02:50 PM   #291
racingfool
racingfool's Avatar
Drives: Miata
What conditions/surface do BFGs like?
racingfool is offline   Reply With Quote
Old 07-21-2021, 02:58 PM   #292
steverife
Warm and dry conditions/surfaces.
Old 07-21-2021, 03:16 PM   #293
racingfool
racingfool's Avatar
Drives: Miata
They like the Lincoln concrete?
Old 07-21-2021, 03:51 PM   #294
steverife
In a different car (ES MR2 Spyder) a few years back, I tested Bridgestones vs BFGs at Lincoln and a low grip local sealed asphalt site. Bracketed ABA testing, both tires in prime condition (sticker BFG's and about 20 runs on Bridgestones) and took enough runs that consistency wasn't an issue. Basically ran the same times on both tires at both sites. I liked the car a lot more on the BFG's and they paid better contingency, so that is the route I took.
Neither tire can hold a candle to the Yoks.
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
