Drives: Toyota 86
Torque spec for an oil pump housing?
Hi guys,
I'm preparing engine build. A Reimax oil pump gear is prepared, but I can't find any torque spec or assembly instructions regarding the oil pump housing from the FR-S service manual. Please let me know the related info. Thanks. Hanjo
#2 |
Drives: 2013 Scion FRS
I need this info too, anyone??
#3 |
Maybe you can find it here -
I'm too lazy to look. Torque specs have been referenced on this forum, but I'm too lazy to search.I asked Bubba, and he said "medium tight". https://www.subarucar.net/sites/suba...FA20D_DOHC.pdf |
#4 |
No spec giving there either. I couldn't find the specification in the engine mechanical manual also.
I've decided on the next best option which is to loosen & tighten the bolt. A torque wrench with an angle gauge helps here or you can mark the bolt, break loose the bolt, and measure the torque value it takes to line up the marks again. |
| The Following User Says Thank You to Trdfrssx For This Useful Post: | Ultramaroon (07-14-2021) |
#5 |
For cryen out loud - jest tighten that sucker down -
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-14-2021) |
#6 |
Link to manual in my sig line
#7 |
Drives: Crapcan
It is not in there. I would measure the diameter and thread pitch of the bolt and go off generic specs for it. Most of the specs in the manual are generic anyway.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (07-14-2021) |
#8 |
M6x1.0 in aluminum... Same as what's spec'd for the oil pan or timing cover?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (07-14-2021) |
#9 |
Drives: Crapcan
7 ft lbs sounds about right. I think that is what the 6mm on the timing cover is spec'd. I'd want to do it in 3 steps since it is a pretty thin cover and I wouldn't want to risk binding on the pump. Hand tight, 4-5 ft lbs, then final torque at 7 ft lbs.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Trdfrssx (07-16-2021), Ultramaroon (07-14-2021) |
| Stock Pulley Torque Specs? (alternator, crank, and water pump) | LuisAntonioSG | Engine, Exhaust, Transmission | 1 | 05-05-2017 11:51 PM |
| Torque spec for lug nuts | wrxneffect | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 09-06-2016 09:39 PM |
| Torque spec for steering wheel nut? | zooki | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-11-2015 03:14 PM |
| Oil pan torque spec? | Astroboy | Engine, Exhaust, Transmission | 1 | 12-23-2014 02:43 PM |
