-   -   Torque spec for an oil pump housing? (https://www.ft86club.com/forums/showthread.php?t=122677)
makinen 10-14-2017 10:51 PM
Hi guys,
I'm preparing engine build.
A Reimax oil pump gear is prepared, but I can't find any torque spec or assembly instructions regarding the oil pump housing from the FR-S service manual.
Please let me know the related info.
Thanks.
Hanjo
Trdfrssx 07-09-2021 05:13 PM
I need this info too, anyone??
humfrz 07-09-2021 10:43 PM
Maybe you can find it here - :iono: I'm too lazy to look. Torque specs have been referenced on this forum, but I'm too lazy to search.
I asked Bubba, and he said "medium tight".
https://www.subarucar.net/sites/suba...FA20D_DOHC.pdf
Trdfrssx 07-13-2021 04:47 PM
No spec giving there either. I couldn't find the specification in the engine mechanical manual also.
I've decided on the next best option which is to loosen & tighten the bolt. A torque wrench with an angle gauge helps here or you can mark the bolt, break loose the bolt, and measure the torque value it takes to line up the marks again.
humfrz 07-13-2021 06:03 PM
For cryen out loud - jest tighten that sucker down - :iono:
Ultramaroon 07-13-2021 08:20 PM
Link to manual in my sig line
NoHaveMSG 07-13-2021 08:29 PM
It is not in there. I would measure the diameter and thread pitch of the bolt and go off generic specs for it. Most of the specs in the manual are generic anyway.
Ultramaroon 07-14-2021 12:52 PM
M6x1.0 in aluminum... Same as what's spec'd for the oil pan or timing cover?
NoHaveMSG 07-14-2021 12:58 PM
7 ft lbs sounds about right. I think that is what the 6mm on the timing cover is spec'd. I'd want to do it in 3 steps since it is a pretty thin cover and I wouldn't want to risk binding on the pump. Hand tight, 4-5 ft lbs, then final torque at 7 ft lbs.
