Old 06-16-2021, 05:55 PM   #15
steve99
Drives: FT86
Originally Posted by hegreer1 View Post
Hey guys,
I promise I have searched a lot and have not found a great answer to my issue.
I previously had a Perrin CAI and the OFT Stage 1 tune that I scaled using Perrin's Scaling.
I just swapped the stock intake back on but kept the Perrin intake tube. I reflashed with the unmodified Stage 1 tune and am now getting very low IAM. Anywhere from .45-.65. I thought it may be gas, but I filled up at a QT with 93, hoping that it would help, and it hasn't.
I am wondering if any of you have any insight as to why this may be?
I also regret never having paid attention to the IAM with the intake on.
Is there anything from the intake install that could be causing my issue?
Also forgot to mention my LTFT seem fine, less than 5%.
Also this is on a 2013 FR-S with just over 100k miles.
What fuel you usong 91 or 93 what county you in ?
also oft petrol tunes iam starts at 0.7 max each startup, if fuel low quality like 91 or most caniadian fuel ( except maybe husky 94) iam will go lower in certian driving conditions.
On oft petrol tunes you need good 93 fuel in most cases to get iam near or at 1
can you post log to www.datazap.me
can sort custom tune for you if needed
gen3v8 (06-16-2021)
Old 06-17-2021, 01:13 PM   #16
hegreer1
hegreer1's Avatar
Drives: 2013 Whiteout FR-S
I am running 93, and I just filled up a few days ago thinking maybe i got some bad gas. I rechecked MAF was inserted correctly and tight, and that all of the hose clamps were tight. I seem to be running very lean from the datalog I just took. Let me know if you think this is maybe a bad MAF, or just a tuning issue.
https://datazap.me/u/hegreer1/61721-...=0&data=1-9-14
Mods: Koyo radiator, Five:AD rear lip spoiler, Perrin CAI and silicone intake tube, Gruppe-S UEL Header, Stage 2 UEL tune by STEVE99
hegreer1 is offline   Reply With Quote
Old 06-17-2021, 01:21 PM   #17
hegreer1
hegreer1's Avatar
I am worried I have a tune that may have been scaled for my intake on it that was improperly labelled on my computer. I have redownloaded the Stage 1 tune from Open Flash's website and with reflash with it tonight. Would having the scaled MAF cause this?
Edit: i checked the values in to raider and they are different from the Perrin values.
Old 06-17-2021, 07:44 PM   #18
hegreer1
hegreer1's Avatar
Any ideas on what may be leaning out my AFR?
Old 06-17-2021, 08:16 PM   #19
steve99
Drives: FT86
Runnig way too lean in open loop ie full throttle target is 12 your round 13
maf scaling incorrect , you on stock intake ?
Old 06-17-2021, 09:41 PM   #20
hegreer1
hegreer1's Avatar
Yeah stock intake box with a perrin intake tube. Do you think it is tune related or something else? Just don’t want to start adjusting tune if there is an underlying issue causing the problem.
Old 06-17-2021, 11:15 PM   #21
steve99
Drives: FT86
Check for leaks , also try cleaning maf
Old 06-18-2021, 01:05 PM   #22
hegreer1
hegreer1's Avatar
I just recleaned the MAF, adjusted the hose clamps and retightened and made sure MAF was in correctly and tight. I then reflashed a freshly downloaded Stage 1 tune from the OFT website.
I went for a test drive and had an IAM of .94!
I will try to get a log later to upload to verify everything looks right.
Old 06-21-2021, 10:58 AM   #23
hegreer1
hegreer1's Avatar
Hey guys,
I found what the potential problem may be. I has reused the standard hose clamp from the perrin CAI on the stock intake box. I may have overtightened it a bit and creased the outlet on the intake box a little. I put on the oem style parallel wire style hose clamp and made sure it was sealing off better.
I ran a new log this morning, let me know what you guys think. It is still running a little bit leaner than the command AFR, but let me know if this could still be the air leak causing this.
https://datazap.me/u/hegreer1/log-16...data=1-5-11-14
Old 07-02-2021, 12:57 PM   #24
hegreer1
hegreer1's Avatar
@steve99 I took a log on my way back from lunch and have narrowed down where my IAM is dropping, but I am not have any knock correction at that point. So I am a bit lost.
I will be swapping my Perrin CAI back on tonight and reflashing the scaled tune for it to see if it makes a difference.
Would you be willing to look over the log? It is a bit of traffic, cruising, and a 3rd gear WOT.
Thanks
https://datazap.me/u/hegreer1/traffi...mark=3237-3238
Old 07-05-2021, 06:04 AM   #25
steve99
Drives: FT86
Thanks
look for Negitive FLKC.
Positive is ok jist observer where your getting negitive flkc, usally at least -1 or greater and look where its causing advance multiplier to drop
Old 07-06-2021, 09:56 AM   #26
hegreer1
hegreer1's Avatar
I reinstalled the Perrin CAI on Friday and reflashed the Stage 1 with Perrin's MAF values and ran a log this morning. IAM seems to be staying up much better than before, but still leaning out a little after 4.5k RPM. I looked at the FLKC from the log this morning and it has a negative value from around 3.6k to about 5k. But the values are less than one. So I am now thinking I may still need you to scale my MAF.
Take a look and let me know what you think.
https://datazap.me/u/hegreer1/perrin...=0&data=1-2-13
Also, thank you again for all of your help. I really appreciate it.
Old 07-08-2021, 07:17 AM   #27
steve99
Drives: FT86
yeah pretty lean round 5000-6000 also ltft at idle and low rpm bit low at -12
yeah can do that shoot me a message
iam, oft
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
