Old 06-15-2021, 09:29 PM   #1
hegreer1
hegreer1's Avatar
Drives: 2013 Whiteout FR-S
OFT Stage 1 low IAM
Hey guys,
I promise I have searched a lot and have not found a great answer to my issue.
I previously had a Perrin CAI and the OFT Stage 1 tune that I scaled using Perrin's Scaling.
I just swapped the stock intake back on but kept the Perrin intake tube. I reflashed with the unmodified Stage 1 tune and am now getting very low IAM. Anywhere from .45-.65. I thought it may be gas, but I filled up at a QT with 93, hoping that it would help, and it hasn't.
I am wondering if any of you have any insight as to why this may be?
I also regret never having paid attention to the IAM with the intake on.
Is there anything from the intake install that could be causing my issue?
Also forgot to mention my LTFT seem fine, less than 5%.
Also this is on a 2013 FR-S with just over 100k miles.
Mods: Koyo radiator, Five:AD rear lip spoiler, Perrin CAI and silicone intake tube, Gruppe-S UEL Header, Stage 2 UEL tune by STEVE99
Last edited by hegreer1; 06-16-2021 at 11:48 AM. Reason: Forgot important information
hegreer1 is offline   Reply With Quote
Old 06-15-2021, 09:40 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Try cleaning your maf maybe during the install you got it dirty or something
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 06-15-2021, 09:59 PM   #3
hegreer1
hegreer1's Avatar
I will try that first thing in the morning. I have a can of MAF cleaner at work.
Old 06-16-2021, 05:38 AM   #4
tomm.brz
Drives: brz 2017 hksv2
Do a custom tune and stop expecting miracles from a canned tune
even stock rom, that is a canned tune, knocks often
If you want perfection you need to custom tune, specially if you make intake mods
Old 06-16-2021, 06:59 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
This might seem like a dumb question but do you have a aftermarket catted or catless header with that tune?
Old 06-16-2021, 09:36 AM   #6
hegreer1
hegreer1's Avatar
I do have a Gruppe-S uncatted UEL but havent installed it yet. I am waiting to get this issue figured out before I add another variable in.
Old 06-16-2021, 10:50 AM   #7
hegreer1
hegreer1's Avatar
I did a quick log last night, if someone could look at it and let me know what they think.
https://datazap.me/u/hegreer1/log-16...=0&data=1-9-14
Old 06-16-2021, 11:47 AM   #8
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
The Stage 2 tune is for catted aftermarket headers, IIRC. If you're still on the stock header, that might be your problem. Should be a Stage 1 flash.
Cephas is offline   Reply With Quote
Old 06-16-2021, 11:48 AM   #9
hegreer1
hegreer1's Avatar
Sorry guys, I did not mean to say stage 2 tune. I have the OFT Stage 1 flashed on the car.
The Following User Says Thank You to hegreer1 For This Useful Post:
Cephas (06-16-2021)
Old 06-16-2021, 01:14 PM   #10
hegreer1
hegreer1's Avatar
Just cleaned the MAF and checked all of the hose clamps, and went for a drive and held a .80 AIM.
Old 06-16-2021, 01:27 PM   #11
RToyo86
RToyo86's Avatar
Id try another log with the MAF cleaned now that IAM is holding higher. AFR before looked lean to me but others can chime in with more experience.
On the subject of tuning @tomm.brz above did my custom tune. I'd consider that to dial your setup and fuel with your header. I have the same header my self.
The Following User Says Thank You to RToyo86 For This Useful Post:
hegreer1 (06-16-2021)
Old 06-16-2021, 01:52 PM   #12
hegreer1
hegreer1's Avatar
Okay, I will do another log tonight and put it up. How are you liking the Gruppe S and tune? Are you running 93 or E85 with it?
Old 06-16-2021, 02:40 PM   #13
RToyo86
RToyo86's Avatar
With tommasos tune the car runs great. I run on Canada Petro 94 which is probably somewhere between good US 92-93 octane.
Pulls nicely, especially when air intake temps are below 75f. I run the car all year round. My winter tune needed some adjustment for our hot humid summers. As it turns out going from 20f intake temps to 90f requires some adjustments
Summer
https://datazap.me/u/mygotousername/...-7&zoom=55-126
Winter
https://datazap.me/u/mygotousername/...r-pull-log-v18
Old 06-16-2021, 02:47 PM   #14
hegreer1
hegreer1's Avatar
Summer
Winter
Those logs look great. I messaged him about customizing a tune for me as well. I appreciate your help.
RToyo86 (06-16-2021)
iam, oft
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
