Old 06-17-2021, 01:50 PM   #1
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
JDL Turbo Kit - Throttle Response
Not sure if this has been covered but I'm finding a few downsides to going turbo.
The 1st one and most obvious is the balance of the car. All the additional weight in the front. Especially since the JDL kit's manifold and downpipe are extremely heavy due to strength. I have come to realize this is the cost of having more power and I can live with that.
The other issue I'm having is throttle response and I believe there is a solution (tuning). Before the turbo kit, the throttle response was phenomenal, rev matching on downshifts was a breeze and precise. After the kit, the initial throttle response isn't there and I have to give way more throttle to get the rpms to rise. I've mentioned this to my tuner (HRI) and his response was that is due to the new MAP sensor.
I'm wondering if this has been the experience for many of you that have gone turbo. Please share your thoughts on how you think I can fix (if possible) this issue.. Thanks in advance.
airindia33 is offline   Reply With Quote
Old 06-17-2021, 03:02 PM   #2
StraightOuttaCanadaEh
Wes
Hmm. Following!
Instagram: @gt86ws
Old 06-17-2021, 03:23 PM   #3
alphasaur
friendly
Drives: 17' 86
afaik, the extra piping associated with turbocharging will effect throttle response as well, I.E on my old platform (mazdaspeed3) a TMIC had better throttle response over a fmic. Tuning can likely mitigate a lot of it. Have you done any weight reduction up from and maybe try moving the battery to the rear?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-17-2021, 03:24 PM   #4
zberz
Drives: 2015 Lightning Red BRZ
Extra weight, meh. I haven't really noticed a difference in how it drives. Still handles beautifully.
As far as throttle response goes, mine hits hard at 3K+, with stock engine feel below 3K. I had to re-learn how to rev match post-turbo, but as long as I keep it past 3K, the response is fantastic.
GTX2867R
Tuned by IAG
If it lends me any credit, I just finished a 1400 mile roadtrip 30 mins ago.
Sent from my SM-G950U using Tapatalk
zberz is offline   Reply With Quote
Old 06-21-2021, 12:48 PM   #5
CSG Mike
CSG Mike's Avatar
Stock engine before and after? The throttle response shouldn't be significantly different.
I'm also turbo, and my throttle response is more or less the same as stock. I'm on a 4bar MAP sensor.
Video for reference.
Old 06-21-2021, 08:11 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
This might be of interest
https://www.ft86club.com/forums/showthread.php?t=139784
Old 06-23-2021, 05:23 PM   #7
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Yup. Stock motor before and after. I am currently running a 3 bar MAP sensor.
Old 07-13-2021, 03:16 PM   #8
Garvin29
Drives: Subaru BRZ limited 2015
@CSG Mike Which turbo kit do you have is your car? JDL too?
Garvin29 is offline   Reply With Quote
Old 07-13-2021, 03:22 PM   #9
CSG Mike
CSG Mike's Avatar
GReddy T518Z.
However, the response is not kit based. If anything, my car's response should be slower; I'm on a journal bearing 18G
Old 07-18-2021, 01:10 AM   #10
jflogerzi
jflogerzi's Avatar
What turbo are you running? HRI is a good tuner..
2013 Series 10 FRS #553
Old 09-23-2021, 07:26 PM   #11
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
GTX 2867R (Gen2)
Old 09-23-2021, 07:47 PM   #12
Calum
That Guy
GReddy T518Z.
What does that mean? Should your setup respond slower because of the 18G but there's some other magic happening? Or is it faster because of the 18G?
Old 09-25-2021, 03:19 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
He is inferring that CHRA technology and bearing type have significantly more of an impact than the kit does. The technology Garrett implements in the 18G's CHRA is quite old, and the journal bearing response is poor, in comparison to a similarly sized ball bearing assembly.
The issue OP is describing sounds like it is all tune based. There's mapping specific to input percentage vs actuation of the throttle. Example-0 15% throttle can be mapped to open the throttle valve 50%. It does not have to be linear either. The tuner may tune the throttle conservatively (50% input is 25% throttle) and map linearly to provide safety against input spikes causing other issues.
Old 09-26-2021, 12:19 PM   #14
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I did not have this problem in the past.
Although I did learn what you can and can't always do in turbo'd car especially at this kind of setup.
GTX2867R
UEL
JDL V1
Alltezza is offline   Reply With Quote
OFT v4.03 throttle response Tristor Software Tuning 29 09-22-2019 04:51 PM
OFT throttle response MyGT86Yas Software Tuning 6 02-26-2018 05:44 AM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
poor throttle response Djen Electronics | Audio | NAV | Infotainment 5 06-18-2013 07:31 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
