Old 06-16-2021, 02:08 PM   #29
Originally Posted by steverife View Post
I mean, I CAN get ICE mode with the long press. But it generally isn't something that happens unless I screw up.
My understanding with the pedal dance is that ICE mode happens with a much greater frequency, at least in an autocross setting.
OK, then it sounds to me like the long press leaves something in play that kicks in before ice mode, but the pedal dance negates it so it falls through to ice mode.
Old 06-16-2021, 02:13 PM   #30
Ice mode is more prevalent during pedal dance because you're switching the ABS to single channel mode
Can you share some more about this single-channel mode? You have my attention.
Old 06-16-2021, 02:25 PM   #31
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Can't believe anyone is driving these cars with the nannies still on. These are such excellent, communicative, and easy to control vehicles.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 06-16-2021, 02:42 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How the heck are you guys getting ice mode so often?
Old 06-16-2021, 02:59 PM   #33
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Not new info, it's buried in here somewhere, goes with the turning off of EBD (electronic brakeforce distribution)
https://www.ft86club.com/forums/showthread.php?t=25494
Easiest to feel when braking mid corner, which you shouldn't be doing but with pedal dance the car senses the light front wheel and reduces braking pressure around the grip of the light front wheel meaning you're basically not braking at all. The single channel mode I mean is that it acts like ABS from the '80s where it reacts to the wheel that's locking and reduces brake pressure across the system to get grip back to that wheel.
Without pedal dance it's computing wheel speeds at all four corners and eases up on the brake pressure on the light front wheel while still allowing the other 2-3 loaded wheels to slow the car down, real useful when you fuck up and want to pull your line in tighter.
I have only experienced it with the pedal dance and an extremely aggressive brake application. If you're gentle in getting on the brakes or I should say, not a fucking idiot jamming on the brakes like I was it will almost never happen. You're basically shocking the tires and the dumb pedal dance mode can't tell the difference between that and ice, the regular ABS/EBD can. This is in autox, not on the street, I'm not dumb enough to think I can outbrake the computer.
/imho
ineedyourdiddly
Old 06-16-2021, 03:20 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
/imho
I have yet to have it happen on track in 5-6 years
Old 06-16-2021, 03:28 PM   #35
steverife
Drives: 2016 Scion FRS
Go find a slick bumpy surface. Get up to about 60 mph, then turn the car right as hard as you can, then turn left as hard as you can while slowing down to about 18 mph. And try to do it better than hundreds of other people.
You might get ice mode every 30 to 50 attempts.
steverife is offline   Reply With Quote
Old 06-16-2021, 03:35 PM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is more the answer that I was looking for. It sounds like AutoX puts you in situations where it is more likely to trigger it.
Old 06-16-2021, 03:51 PM   #37
strat61caster
For me it was 1:1 with trying to break the brake pedal, regardless of pavement or suspension loading.
ineedyourdiddly
Old 06-16-2021, 03:52 PM   #38
steverife
Absolutely. Mitigating ice mode (or brake lockup in non-ABS cars) is a pretty integral part of the autocross skillset.
...and I think that is why the bulk of "serious" autocrossers in twins don't seem to mess with the pedal dance.
Old 06-16-2021, 04:01 PM   #39
Goingnowherefast
This is a good point. As I was reading that I was like "uh what track are you driving that has you doing that maneuver". Make sense why I haven't had that happen in my 20-30 track days using the long press method (I don't autoX anymore).
Old 06-16-2021, 05:39 PM   #40
Not there but that's ok. I'm not trying to put you on the spot. I get what you mean about per-wheel vs whole car.
Old 06-16-2021, 07:29 PM   #41
CSG Mike
CSG Mike's Avatar
Originally Posted by Breezio View Post
Alright peeps. Please clear this up for me.
I thought I read that ICE mode was an occasional problem WITH using pedal dance, and NOT an issue when using the long press.
Which is it? I've always long pressed and never had ice mode. I've shied away from pedal dance for fear of ice mode, plus long press has never intervened in at any time when the run wasn't gone to shit anyway.
Ice mode is *always* a driver error, and *always* a potential issue, with or without the pedal dance.
CSG Mike is online now   Reply With Quote
Old 06-16-2021, 07:29 PM   #42
CSG Mike
CSG Mike's Avatar
I have no experience with this, but do have some experience with programming.
If the code kicks in during the least intrusive mode (pedal dance) it would seem to me it would kick in in pretty much any mode. I suppose the long press could leave a case that becomes active in before ice mode, that is absent from the pedal dance, but that seems unlikely.
Just a thought.
The logic is sound.
Pedal dance preserves ABS, as the ABS ecu is separate from anything the pedal dance does.
The pedal dance does not affect ABS or Ice Mode.
WTB: pedal dance box captain awesome Want-To-Buy Requests 6 08-19-2019 12:37 AM
Pedal dance problem Sapphireho Scion FR-S / Toyota 86 GT86 General Forum 43 07-31-2017 09:25 PM
Pedal dance Simqc Issues | Warranty | Recalls / TSB 6 05-22-2016 09:56 PM
OFT - Pedal Dance Mode. RustySocket Software Tuning 2 08-24-2015 06:55 PM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
