Old 06-12-2021, 02:02 AM   #1
Jenster
Drives: Toyota 86 2014
Reverse catch disabled
Hi,
Have a second hand Toyota 86 2014. Had the clutch replaced. After the replacement, the reverse catch does not need to be pulled to put the car in reverse. My mechanic had a look but cant figure out how to re-engage it and feels like the swap out of the clutch should not have affected the lever.
Any tips I can pass on are appreciated
Jenster is offline   Reply With Quote
Old 06-12-2021, 07:36 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by Jenster View Post
Hi,
The shifter wasn't reassembled correctly. There is a plate with a notch in it that gates reverse. This plate is almost certainly missing or misaligned. Watch a video on a "short shifter install" and you'll see the plate.
Sent from my ONEPLUS A5010 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
saltywetman (06-12-2021), Tcoat (06-14-2021)
Old 06-13-2021, 07:52 PM   #3
Jenster
Thank you!
Old 06-14-2021, 11:55 AM   #4
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
From the repair manual. Pretty straight forward
Important to note, make sure when you adjust the gap that the top plate is truly parallel to the 1-2 shift direction, as the shifter will "ride" along this plate. The holes are slotted so it is easy for this to be misaligned.
If it is too tight at the bottom near 2nd gear position, it will be difficult to shift into 2nd. Vice versa on 1st gear.
Get everything in position and tighten them down slightly, then row through the gears and ensure shifts are smooth before final tightening.
wolffbite is offline   Reply With Quote
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
bcj (06-14-2021), humfrz (06-14-2021), Tcoat (06-14-2021)
Disabled parking question.... PetrolioBenzina Scion FR-S / Toyota 86 GT86 General Forum 22 11-19-2018 06:56 PM
OFT disabled DTCs bzdont Software Tuning 3 09-15-2017 10:49 PM
Cruise control temporarily disabled? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 08:35 PM
Disabled the driving aids. Here are my impressions. diss7 Scion FR-S / Toyota 86 GT86 General Forum 284 01-10-2014 07:36 PM
NAV Voice Directions disabled? ShoGun Electronics | Audio | NAV | Infotainment 0 07-15-2012 09:06 AM
