Old 07-27-2012, 05:04 PM   #15
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by SpeedR View Post
2JZ-GTE has 8.5 and can hit +30PSI with the right turbo. lower compression ratio will alow alow for a lot more power.
Thats not true at all. Our 2jz engines are 10-10.5:1 Flat top pistons. And we run 60-70psi!
The compression ratio does not dictate how much power you can make!
Don@Accelerated is offline   Reply With Quote
Old 07-27-2012, 05:05 PM   #16
Don@Accelerated
Originally Posted by subatoy View Post
makes sense. soo if you are not looking for crazy numbers you can stay with the stock pistons just fine?
I would be very happy with 250 WHP
I'll be testing 250 whp. My guess is that the engine won't fuss at 250whp at all.
Don
Old 07-27-2012, 05:23 PM   #17
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
pistons are all fine and dandy but just because it lowers the compression doesn't make this safe will you guys make a heat chart of the piston when it fires and has compression in the cylinders because with the way the gas ignites the air fuel mixture this can become dangerous. i am sure you guys are all awear of this but i would really like to see some charts. One good rule of thumb is to drop compression by about one point for every 15 pounds of boost. However, keep in mind that dropping compression too far will reduce engine power when off of boost, increasing turbo lag and decreasing drive-ability. Small combustion chambers tend to do better with a deep piston dish, and larger ones do better with a shallow dish. Ideally, you want a fairly small, open combustion chamber with little to no quench (flat) area and a deeply dished piston. With the design of the top of the pistons im kind of worried about the mixture of the gas. just was hoping for a more of a semi flat style i guess.
http://www.jcmmachine.com/detonation_preignition.htm
that high spot on the piston is what im concerned about on the lower left of the picture
20valvewynn83 is offline   Reply With Quote
Old 07-27-2012, 05:25 PM   #18
Don@Accelerated
The design needs to be that way for the direct injection. Its no coincidence that the nozzle design accomodates.
The Following User Says Thank You to Don@Accelerated For This Useful Post:
20valvewynn83 (07-27-2012)
Old 07-27-2012, 05:27 PM   #19
rusty959
Drives: DGM BRZ limited
I believe you forgot this engine is direct injection. The shape of the piston helps in this case.
Edit: got beat to the punch.
rusty959 is offline   Reply With Quote
The Following User Says Thank You to rusty959 For This Useful Post:
Old 07-27-2012, 05:30 PM   #20
serialk11r
Drives: '06 AM V8V Coupe
Just for curiosity's sake, how much power do you think the stock pistons could hold up to, say with ethanol? 12.5 + E85 + lots of boost usually get along fine
Old 07-27-2012, 05:31 PM   #21
20valvewynn83
yes this it true it helps the mixture but i was really conserned about the lower left part of the picture. i know on the toyota 20 valves when people would turbo them they were having this problem with the mixture. and that too is direct port
with that type of design on the 20valve they were causing hot spots in the pistons
Old 07-27-2012, 06:10 PM   #22
Don@Accelerated
By the time we throw E85 into the mix. I bet the rods will be a limiting factor!
Old 07-27-2012, 06:11 PM   #23
Don@Accelerated
Originally Posted by kmbkk View Post
Don, any word on pricing yet?
Don't know yet, but I would suspect pricing similar to the majority of other 4 cylinder kits.
Customs sets will be priced slightly higher.
Old 07-27-2012, 06:11 PM   #24
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Fantastic Don! Keep up the great work man.
denkigrve is offline   Reply With Quote
Old 07-27-2012, 07:17 PM   #25
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I hope the rods handle 350whp without issues. I've seen stock SR20 roller-rocker/VE rods pushed to damn near 600whp before failure. 500whp stock block.
But I'd be happy with a solid 350whp reliable unopened engine, if that's possible with just a few bolt ons and bigger injectors.
Coheed is offline   Reply With Quote
Old 07-28-2012, 06:30 AM   #26
noAE86
Drives: ae86, etc..
FA20 is direct port and direct cylinder injection,
hence the reason for the piston top, if design is correct then piston cooling should be pretty even from the direct cylinder injection,
to solve the hot spot problem in the 20valve was only a matter of ceramic coating the top, we did this to our unlimited class racer,
don: do you think these pistons will need any coating on them?
noAE86 is offline   Reply With Quote
The Following 3 Users Say Thank You to noAE86 For This Useful Post:
20valvewynn83 (07-28-2012), sato (05-02-2018), UncleFester (07-28-2012)
Old 07-28-2012, 08:01 AM   #27
arghx7
Drives: car
How was the piston bowl designed on these Wiseco parts?
Old 07-28-2012, 08:09 AM   #28
Don@Accelerated
I believe the first set will have no coatings. The production pieces will have at a minimum skirt coatings.
Accelerated Performance FRS/BRZ-300 Turbo Kit Don@Accelerated Forced Induction 104 11-26-2012 03:55 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
