Old 05-08-2021, 11:08 PM   #4383
Jchang
Drives: 2018 Subaru BRZ Ts
Just making sure, will the stock BRZ tS wheels fit if I install RCE yellow springs? The springs drop about 20mm, and the stock wheels and tires are 18x7.5, 215/40/18
Jchang is offline   Reply With Quote
Old 05-09-2021, 07:48 AM   #4384
Vital
Drives: 2015 BRZ
Yes they will fit
Old 05-27-2021, 06:28 PM   #4385
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
This is a bit complex, but even anecdotal input would help. For my fronts, I have a winter setup that I'm happy with. My summer setup, visually, looks like it has a big gap above the wheel.
Winter
15mm spacer
18x8 +42
Michelin X-Ice Xi3, 225/40
Slight rub against the fender liner at full lock. Hasn't been a problem.
Summer
15mm spacer
18x8.5 +48
235/40
I'm lowered roughly an inch on HKS Hipermax GT coilovers. I'm due for new summer tires. How could I bring my summer setup more in line with my winter setup?
My original plan was to try 245/40 for a wider effect, bringing the outer edge of the wheel closer to the fender. I've found at least one thread that makes me think that won't have the desired effect (and may rub), though. Would 245/35 or 255/35 get me closer?
TheBRZsKnees is offline   Reply With Quote
Old 05-28-2021, 04:56 AM   #4386
churchx
churchx's Avatar
Drives: 2014 GT86
Imho it's wrong to care much about fitment/stance in relation with winter tires. Grip in winter already is scarce, not worth to compromise it with looks. And going for very wide tires in winter is against common practice that usually is opposite, for going narrower for winter tires, for tire to easier cut through packed snow/slush, to not float above in similar fashion to aquaplaning.
Old 05-28-2021, 09:19 AM   #4387
Vital
Drives: 2015 BRZ
Winter
15mm spacer
18x8 +42
Summer
15mm spacer
18x8.5 +48
235/40
Well you might be rubbing because the 235/40 tire is a lot taller than your winter tires. For your Summer tires get 245/35 or 255/35 (which has more choices) and you'll be fine and shouldnt rub.
Old 05-30-2021, 12:09 PM   #4388
ZDan
ZDan's Avatar
Drives: '23 BRZ
Summer
15mm spacer
18x8.5 +48
235/40
So you're effectively +33 offset.
What's your front camber? Assuming it's lowish, you might add some with camber bolts and offset top mounts. FWIW I'm on 17x9 +35, 245/40-17, -1.25" ride height and it looks pretty bad-ass at -3.5 front camber...
If you're at less than 1.5 front camber, I think that's your issue more than tire size. Tire size for you looks like it will be somewhat dictated by whether you want Extreme Perf 200tw, or another category. For Extreme Perf, looks like 225/40-18 might be best choice for tire diameter being closer to stock. 235/40-18 a bit taller, but IMO also works. Not much selection for 245/35-18 in Extreme Perf but looks good in Max Perf and other categories. 255/35-18 on 8.5" wheel works but not optimal and will give a more bulgy look.
Old 05-31-2021, 06:16 AM   #4389
mykoe
Buying a new wheel setup and wanted to make sure itll fit. On coilovers.
ESR FR1s
18x8.5 +30
18x9.5 +35
Tires Sizes:
245/35ZR18
265/35ZR18
2014 BRZ Premium
2018 Accord Base
- Mike
mykoe is offline   Reply With Quote
Old 06-01-2021, 01:01 AM   #4390
XPLSV
XPLSV's Avatar
Drives: 2015 FR-S RS1.0
I have a 2015 FR-S Release 1.0. Most everything is stock on it. I finally got through the original rubber last fall and put a set of snow tires on the stock 17" rims, where they will stay for the Colorado winters. I just picked up a set of the black TRD alloy wheels: 18x7 +35 for the front and 18x7.5 +35 for the rear. No plans on changing anything else up for the foreseeable future. Would appreciate some tire size suggestion. Thanks!
XPLSV is offline   Reply With Quote
Old 06-01-2021, 10:36 AM   #4391
Vital
Drives: 2015 BRZ
ESR FR1s
18x8.5 +30
18x9.5 +35
Tires Sizes:
245/35ZR18
265/35ZR18
It will fit on coilovers no problem. Just keep in mind people have mentioned with wide tires and lower offset wheels it does rub on a tab where the rear bumper connects to the fender well.
Old 06-01-2021, 10:37 AM   #4392
Vital
Drives: 2015 BRZ
You should use 225/40/18s for those wheels.
Old 06-02-2021, 10:18 PM   #4393
TheBRZsKnees
Drives: 2014 BRZ
Right now, no camber at all. I went with 255/35. I'm pretty happy with the visual improvement, but I do get a bit of rub on the fender liner at full lock.
I understand where you're coming from, though. I think in a way, I shot myself in the foot since I was also considering lowering the car a bit more. To do that, I'd probably need some negative camber, and I think that's no longer an option if I'm already getting some rub on the inside at lock.
Old 06-03-2021, 11:37 PM   #4394
mykoe
What would you run in the rear for no rub?
2014 BRZ Premium
2018 Accord Base
- Mike
Old 06-04-2021, 10:01 AM   #4395
Vital
Drives: 2015 BRZ
Again the rubbing in the rear might just depend on how low you are really. More than likely you might be alright my post just more of a caution that it could happen.
Anyway check out this thread i think people having been using 265/35 in the rear. Hopefully this helps you.
https://www.ft86club.com/forums/showthread.php?t=41083
Old 06-06-2021, 09:09 AM   #4396
gpvecchi
gpvecchi's Avatar
Do you know if there are differences in rear track width between different MY?
Wheelitfit.com shows a completely wrong measure for my car, I have around 1 cm less: 225/40 on 8x18 ET45, camber -2.1 degrees and I barely have 15 mm...
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
