Old 06-01-2021, 11:38 AM   #1
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
Rod Bearings/Main Bearings
So I am now building the block. I finished the valvetrain, trans, and suspension. In my search for information, i have come up short on how to access what bearing sizes i would need. I am going to be using the stock crankshaft. I found that King makes some pretty good bearings that last but im stuck looking at different sizes.
I am not going to modify the stock crank, so my question is the following. Where can i find the dimensions for the stock OEM bearings to compare? Also, has anyone used the King XPG bearings on a stock crank? If so what size did you use to provide the correct lubrication and avoid contact
Fa20Toybaru is offline   Reply With Quote
Old 06-01-2021, 12:19 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You need to go through the procedure in the service manual to determine what size bearings you will need.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (06-01-2021), Fa20Toybaru (06-07-2021), Ultramaroon (06-18-2021)
Old 06-01-2021, 01:33 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I have an IAG block and I believe they use those bearings and the New Subaru FA20 DIT WRX crankshaft . Maybe just contact King and ask which bearings you should use then you dont run the risk of using the wrong ones
TommyW is offline   Reply With Quote
Old 06-02-2021, 01:19 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
They are can recommend a type of bearing but not the size.
The only way to know what size he needs is to remove the ones already in there.
Like I said in his other thread.
If you are asking these types of questions you really shouldn't be building your own engine.
Old 06-07-2021, 01:21 PM   #5
Fa20Toybaru
FA20ToyBaru
Drives: Manual
Thanks for providing this information. I have not been getting any notifications from this thread. I will use your post as a guide.
Old 06-07-2021, 01:30 PM   #6
Fa20Toybaru
FA20ToyBaru
Drives: Manual
Thanks, yea ive talked to a couple of builders that gave me some guidance. I was having a hard time seeing what the oem sizes were. I wanted to see if i should look into standard or get a different size. Since i was going to use a new crank i figured i could go standard but measuring would definitely help. King, Real St, and IAG recommend standard if not using an old crank. I know some like to run tighter and some looser. Ill look into it some more.
Old 06-07-2021, 01:33 PM   #7
Fa20Toybaru
FA20ToyBaru
Drives: Manual
Dang bro! Just a negative nancy! We all start somewhere. Thanks, I guess, for your input.
Old 06-07-2021, 01:52 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is kind of a faux pas to post multiple threads about the same thing in different places. If you look at forum member "Ultramaroon" he has a link to the service manual in his sig. It is best to start at the manual.
jeepmor (06-17-2021)
Old 06-17-2021, 10:00 PM   #9
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
All FNGs take their lumps, you're no different. I'm a seasoned jeep guy still asking dumb questions in here about this car. Learn to skim off the ribbing and take the info and run with it.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
Rod Bearings/Main Bearings Fa20Toybaru Engine, Exhaust, Transmission 2 06-02-2021 01:15 AM
BRZ wheel bearings same as 86? JackRabbit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-06-2020 01:52 PM
Wheel bearings gone bad rustymuffler Issues | Warranty | Recalls / TSB 25 05-02-2019 11:21 AM
The OEM rod bearings debate nelsmar Engine, Exhaust, Transmission 58 12-02-2013 12:51 PM
