| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: Q5 + BRZ + M796
Legit or not? Alfadan’s 7.5L 4 cylinder
7.5L NA 4 cylinder that revs continuously at 5500 rpms and makes 650hp using a reinvented connecting rod and maybe Freevalve and Mahle is involved. Sounds too good to be true.
#2 |
My guess is variable compression rods like those used in the Infiniti motor, which should eliminate the need for balancing shafts. Mahle is working on special pistons. Freevalve is doing the heads and pulling off some major improvements in power and efficiency, which is allowing high compression.
Just a guess.
#3 |
There is not one single word on the internet other than this video. Not one word. That makes me wonder.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (06-01-2021) |
#4 |
Dismember
Drives: 2013 Red Scion FR-S
Oh boy. All this new tech! Maybe in 50 years it will be as efficient as a BEV of 10 years ago.
#5 | |
I think there is potential.
#6 |
Because compromise ®
Drives: Red Herring
What are you talking about?? Look at all those words I've just read!
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Tcoat (06-01-2021) |
#7 | |
![]() BTW, do you want to buy some humfrzcrypto coins?? |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#8 | |
You asked the question "Legit of not"? Why ask the question if you already feel you know the answer?
#9 | |
I was hoping to hear more from engineers whether the claims are even within the realm of possibility. He talks about the historical limitations, but not as much about the proposed motor. The specific output isn’t that high, but this motor would have giant pistons and/or a long stroke. I guess I could wait for an Engineering Explained video on the limitations of such a motor.
#10 |
Drives: 2013 Scion FR-S Series 10
https://www.thehulltruth.com/boating...boards-16.html
Found this thread ripping the guy and his design apart and his practice of trying to sell people on the idea of what it could be, yet can't seem to actually provide meaningful information. The owner is in the thread doing his best to defend himself. Apparently the design patent is for a "scotch yolk engine." Someone on the forum linked the patent filing. I guess it is a sort of "holy grail" engine that nobody has figured out how to make it work. People are claiming the owner of Alfadan is intentionally hiding the truth about the engine design from investors because he doesn't want them to know it isn't really new or innovative. It just doesn't work, period. They do not have Freevalve technology. They are using a normal cam-design. Most of their claims seem to be dependent on a "2 cylinder" prototype they outsourced for construction and testing and claim it will scale up, but they aren't releasing info on the prototype. Also, it has 50% fewer parts and weighs 50% less because they are comparing a four cylinder to an eight cylinder. So the engine itself is not particularly innovative. They are just using numbers to trick people. The guy used $250K in grant money to sell himself shares of the company so he has zero risk. He is now raising $1M with the goal of $25M and I see people are calling him out because that money may be used to pay salaries that include friends and family. Basically, it is like a bad shark tank episode. Numbers! Numbers! Numbers! Growth! Money! What about the design? Did you see my promotional video!? It talks all about it. Here are some confusing Shark Tanks to help you waste time if you are in the mood. Last edited by mazeroni; 06-01-2021 at 02:03 PM. |
| The Following 2 Users Say Thank You to mazeroni For This Useful Post: | Irace86.2.0 (06-01-2021), NoHaveMSG (06-01-2021) |
#11 |
Drives: Crapcan
I like his, "this is my last post" then proceeds to get worked up and posts again.
What a cluster eff that is. It almost resembles.....one of our threads
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | bcj (06-03-2021) |
#12 |
Drives: Nevermorange FRS
So this is like the Theranos of Marine engines... Hmm. Does the owner talk in an uncharacteristically deep voice?
RED FLAG! Edit: The supposed "secret sauce" is that they figured out some magical connecting rod design that allows the piston to have a linear speed throughout the stroke, something doesn't occur currently as the connecting rod changes it angle as crank rotates and that results in dynamic piston speeds throughout the stroke that creates an inherent imbalance in Inline 4 cylinder engines. This necessitates balance shafts or a reduction in peak RPM as the displacement increases. Supposedly this secret connecting rod means there is no imbalance they can have very large displacement 4-Cyl engines that rev really high. So uh yeah... Good luck with that.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | WildCard600 (06-03-2021) |
| Faction Fab Legit? | Strife26 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-11-2019 10:48 AM |
| Are these BBS legit? | leevanf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-05-2019 10:23 PM |
| Is this legit site? | MasterAzir | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-04-2016 12:25 PM |
| THMotorsports legit? | JoeyMarch | Other Vehicles & General Automotive Discussions | 3 | 03-01-2015 10:29 PM |
| Are Cambertires legit? | aaronosaurus | Tracking / Autocross / HPDE / Drifting | 19 | 09-11-2013 05:59 PM |
