Old 05-31-2021, 10:31 AM   #1
J95
J95's Avatar
Sound with decat headers + the rest OEM?
Hey,
I wonder if anyone has any experience of using some decat headers but keeping the rest OEM. Well I have an AM axleback, but it is not making a big difference
Will I get a nice improvement in sound already with the decat headers? I definitely want it louder than now but nothing too extreme. So I wonder if decat headers is enough or should I consider also ordering a front pipe
J95 is offline   Reply With Quote
Old 05-31-2021, 10:48 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Unless you plan to tune leave the cat inside the header alone.
Change the front pipe out if you just want to change sound.
The Following User Says Thank You to RToyo86 For This Useful Post:
J95 (05-31-2021)
Old 05-31-2021, 12:15 PM   #3
J95
J95's Avatar
Thank you, but I already changed the front pipe in the past...
I tried a Cobra decat resonated front pipe, the gains in sound were soo low with my current setup
Old 05-31-2021, 12:57 PM   #4
Thefalls
Thefalls's Avatar
Drives: Corolla GT
With the decatted headers and the rest stock you won't get much extra volume in the sound. With loss of the stock heat shield on the oem headers you will get some ticking sounds and a bit of rasp (minor) due to loss of oem cat in the header.
Your best bet will be a dual resonated or resonated/catted front pipe paired with a nice backbox. If you have an exhaust shop local to you then better discuss what you really want and go from there.
Thefalls is offline   Reply With Quote
The Following User Says Thank You to Thefalls For This Useful Post:
J95 (06-01-2021)
Old 05-31-2021, 11:51 PM   #5
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Here is my car with Tomei UEL headers and the rest stock
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
acro (06-01-2021), J95 (06-01-2021)
Old 06-01-2021, 04:27 AM   #6
J95
J95's Avatar
Perfect example thank you!
So, in video one can only guess about the loudness and quality of sound. Could you tell me your impressions, how big was the change compared with stock headers?
And how was the change when you installed the catbck?
Old 06-01-2021, 10:52 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've had my car with catless headers with the rest stock, and catless headers with aftermarket front pipe with a high flow cat and the rest being stock. I thought both setups sounded like shit.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (06-02-2021), J95 (06-02-2021), x808drifter (06-02-2021)
Old 06-01-2021, 11:33 AM   #8
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
With only the UEL header and the rest stock, you just have a nice rumble under your feet and it sounds meaner.
When I added my Corsa catback, it did get much louder!
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
J95 (06-02-2021)
Old 06-01-2021, 09:49 PM   #9
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
When I picked up my car it was stock except for an ebay "cold air" and a muffler delete. I had planned on immediately going for some sort of exhaust work but with just the delete it sounded much better than I thought it would. Until you're ready to get the car tuned I would hold off on the cats. Mufflers do most of the work quieting the car down anyways
aKaGorganZola is offline   Reply With Quote
The Following User Says Thank You to aKaGorganZola For This Useful Post:
J95 (06-02-2021)
Old 06-02-2021, 07:25 AM   #10
J95
J95's Avatar
You mean a complete Muffler delete?
I have already an AM muffler. It´s for sure louder than the OEM but still not enough. So I still want to believe that a 4-2-1 catted EL would be a noticiable change
But based in your answers it seems I would need some AM midpipe too...
Old 06-02-2021, 09:30 AM   #11
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I would just make sure you leave the front pipe cat or you will be setting off car alarms…the Corsa has a pretty larger muffler at the axle and it’s still loud (this is with me keeping the stock catted front pipe)
J95 (06-03-2021)
Old 06-03-2021, 09:20 AM   #12
aKaGorganZola
100%. I didn't know it had the muffler delete until after I bought my headers. My original plan was to just do headers first and do a cat back down the road but these cars straight piped are LOUD. Start up especially, I felt bad for my neighbors those couple weeks.
But yes if you have the axel back already in there then getting a set of decat headers will also be a huge improvement. Louder yes but the bigger improvement I think it's the low end deeper sounds you get.
I'm currently running a tomei uel decat, OP, invidia catted fp, and the Perrin 2.5 resonated cat back. The noise is imo nearly perfect for these cars but I also have the the tomei ti decat front pipe that I'm waiting to get welded before it goes back in.
TLDR Running cats you don't really need a muffler but once you start removing the cats you will definitely want a good quality muffler if not a full cat back to clean up the noise lol.
The Following 2 Users Say Thank You to aKaGorganZola For This Useful Post:
BrahmaBull1990 (06-03-2021), J95 (06-09-2021)
Old 06-03-2021, 09:33 AM   #13
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I just had my car re-tuned and it’s cold start is at 2.5k and I can’t take the car in the morning anymore out of courtesy to my neighbors. I’m calling my tuner today to see if we can drop the cold-start down because I do not have a catt in the header to heat.
aKaGorganZola (06-03-2021)
Old 06-03-2021, 09:37 AM   #14
aKaGorganZola
Phone mic doesn't do it justice but here's my car with the muffler delete and decat headers vs after the rest of the exhaust was installed
J95 (06-09-2021)
UEL headers sound level (volume) Xbk47 Engine, Exhaust, Transmission 15 12-11-2021 01:31 AM
Fujitsubo Authorize R + Catless Headers - sound juicyg6 AUSTRALIA 0 08-28-2019 09:55 PM
Question Headers, Sound, Emissions Mase123y Engine, Exhaust, Transmission 6 03-06-2019 06:13 PM
best sound : ft86speedfactory vs JDL headers uel catted pepe Engine, Exhaust, Transmission 8 10-23-2016 06:34 PM
Decat stock vs. aftermarket header (with OpenFlash)? Tor Engine, Exhaust, Transmission 3 07-15-2016 09:53 PM
