Old 07-15-2016, 04:56 PM   #1
Tor
Tor's Avatar
Drives: Toyota GT86
Decat stock vs. aftermarket header (with OpenFlash)?
Would removing the cat of the stock header (hammer/chisel way) be close to the effect of an aftermarket EL Header?
Are there any experience if it's possible to use the OTS OpenFlash EL tunes with a stock decatted header?
Is there a noticeable change to the sound level of the stock header without the cat? (Did anyone come across a sound file of a decatted stock header on stock exhaust?)
Thanks.
Tor is offline   Reply With Quote
Old 07-15-2016, 05:05 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I doubt it will be as effective but it will free up some flow as well as make it louder and likely more raspy. I am sure a off the shelf tune would be fine but I always recommend a custom tune anytime anything is changed like that. The plus side is that doing that is cheap as... (insert your mom joke here) and its stealthy
Old 07-15-2016, 06:04 PM   #3
Sarang
Drives: 2010 LGT
Wasn't there just a thread about this?
Here it is:
http://www.ft86club.com/forums/showthread.php?t=108221
Sarang is offline   Reply With Quote
Old 07-15-2016, 09:53 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
That answered all of my questions. Thanks.
I am seriously considering this route a long with an OpenFlash tablet or a Tactrix cable.
Stealth, cheap and effective!
I saw a used header for approx. 200$ locally. I would might pick that up to use for the experiment and have my original intact.
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
OpenFlash Header 2 and OpenFlash Header 3: In Stock! Shiv@Openflash Engine, Exhaust, Bolt-Ons 6 02-10-2016 01:10 PM
FS: New OFH OpenFlash Header with stock OEM gaskets (Socal) tracerit Engine, Exhaust, Bolt-Ons 0 06-10-2015 08:26 PM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
