Drives: '18 WRB BRZ Limited w/ PP
Are these track coolant temps acceptable?
Hi all,
Got a JR Dual Rad/OC put in. In a fairly hot day (70F and very sunny) the cooler did its job and kept the oil at around 230F the whole time on a stock power 2018. I noticed that the coolant was hanging out around 210. I don't have the data logged, but I think it might have had some peaks at 220. Is this within acceptable range? I assume the coolant temp is higher than when the car was stock without an OC because I am now putting more heat into the system from the oil. Fans are working fine and I tried pretty hard to salvage the stock rad air blocking foams as much as I could (but it's not perfect) |
#2 |
30 minute maintenance
Drives: My18 wrxsti
I think it`s acceptable. Slightly higher water temp than i would have thought from the system, But as you said
In similar ambient temp I`m seeing 195 water and 222 oil. Stock rad and a dual pass oil filter |
#3 |
210/230? Totally acceptable.
Add hood vents for even more cooling, and you can also blast your heater (AC off) as well. |
| Coolant temps with Jackson radiator? | dstrout | Engine, Exhaust, Transmission | 1 | 07-11-2018 03:26 PM |
| FLKC in high gears (e.g track). What is acceptable? | Tor | Software Tuning | 61 | 11-02-2017 08:24 AM |
| Coolant Temps Running High | Dezoris | Tracking / Autocross / HPDE / Drifting | 43 | 09-29-2016 11:58 AM |
| Coolant Temps WAY TOO HIGH | itsjustdavep | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 08-25-2016 01:41 PM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
