Old 05-11-2021, 06:23 PM   #4061
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by N_Raged View Post
That's what I was afraid of, but the fronts look normal like photos of actual tS' from the factory. The rear is a whole inch higher than the front with enough fender gap for my fist lol.
Was everything tightened down while the control arm was under load?
The Following User Says Thank You to RToyo86 For This Useful Post:
N_Raged (05-11-2021)
Old 05-11-2021, 06:38 PM   #4062
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
That could just be due to old tired suspension sagging over time.
Nah. Had pretty fresh PP spring/dampers before that. Bout 20k on em when they were pulled.
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
Old 05-11-2021, 06:53 PM   #4063
N_Raged
Drives: 2019 BRZ Sport-Tech RS
No, first time doing this on a twin. I didn't recall any of the DIY guides on here or YouTube mention this tip. Thanks I'll keep it in mind when I take it all apart again to have a look.
N_Raged is offline   Reply With Quote
Old 05-12-2021, 11:16 PM   #4064
N_Raged
Okay I loosened and retorqued the rear under load and there's no change in ride height. Compared to other people here who installed tS springs on stock struts mine are 0.5" higher in the front and 1.0" higher in the back. At this point I'm just going to agree with the reason being the high pressure from the Bilsteins combined with the stiffer tS springs. I'll give it more time to hopefully settle more.
The Following User Says Thank You to N_Raged For This Useful Post:
RToyo86 (05-13-2021)
Old 05-13-2021, 09:00 AM   #4065
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Had my alignment done yesterday, after I installed my RCE Yellows and B6s, with crash bolts up front. The tech said the front evened out at about -1.1°. I didn't ask about the rear, since my understanding is it's not adjustable, but when I looked at my printout afterward, it said the rears were at -2.0.
That seems like a discrepancy in the wrong direction? I thought we were supposed to be even all the way around, or maybe a bit more negative in the front. Am I looking at rear LCAs to get there?
Cephas is offline   Reply With Quote
Old 05-13-2021, 09:07 AM   #4066
RToyo86
RToyo86's Avatar
The rear suspension is a multilink will add camber when the car is lowered. The fronts being McPherson strut don't really change at all which is where camber bolts come in.
Adjustable LCAs are an option if you want everything the same.
Cephas (05-13-2021)
Old 05-13-2021, 10:55 AM   #4067
Cephas
Cephas's Avatar
Gotcha. Yeah I was just surprised how much camber the rears got off such a mild drop (20mm). Guess I'll drive it for awhile and decide whether to look for more camber up front, or less camber in the rear. Just trying to keep the handling balanced.
Old 05-13-2021, 11:10 AM   #4068
Racecomp Engineering
The rear isn't adjustable from the factory, so those numbers are expected for what you have. It'll still be good like that (nice that it's even at least in the rear). With adjustable rear LCAs, I'd take the rear down a smidge to around -1.5 to -1.8 for a daily driver.
- Andrew
Cephas (05-13-2021), Tatsu333 (05-14-2021)
Old 05-13-2021, 11:11 AM   #4069
A full inch doesn't sound right. Are you sure the rear spring perch is seated correctly on the Bilsteins? Did it settle at all?
- Andrew
N_Raged (05-13-2021)
Old 05-13-2021, 12:32 PM   #4070
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Really depends on what is your goals with the car. I wouldn't do any less camber in the rear, and if anything add more in the front. -1.1⁰ in the front is almost nothing.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Old 05-13-2021, 12:50 PM   #4071
Cephas
Cephas's Avatar
Yeah that's a fair question. There's no track time in my foreseeable future, so basically my goals at the moment are to make it a little more fun on the street, and shore up some of the weaknesses it had from the factory (i.e. plowing the front into corners). But of course as a street car and DD, I have to strike a balance so I'm not murdering tires, sacrificing ride quality, etc.
Old 05-13-2021, 12:53 PM   #4072
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Camber doesn't eat as much tire as too much toe does. I wouldn't reduce camber in the rear for stability. You may want to add some in the front next time you do an alignment.
The Following User Says Thank You to timurrrr For This Useful Post:
Cephas (05-13-2021)
Old 05-13-2021, 01:19 PM   #4073
N_Raged
- Andrew
Yes the end if the coil is right up against the zigzag thing on the spring perch.
After a few drives the rear settled 3/16" to 27 3/16".
I'm not sure if this is an effective measurement but I also measured the distance between the pinch weld jack points and the ground. The rear jack points are only less than half an inch higher off the ground than the front jack points (with a half tank of fuel). So that doesn't seem like a huge rake to be concerned about right?
Whatever, I'm gonna stop worrying and just drive the thing. Looking at real life photos of the 2020 tS, there's a comical amount of fender gap for a car with performance tuned springs and mine doesn't look that much different.
Old 05-16-2021, 04:01 PM   #4074
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Do threaded rod ends in bending fail much? Are threaded rod ends in bending acceptable ever? Seems like a lot of aftermarket companies offer adjustable suspension that puts the threaded rods in a bending position. I've just read that this is a bad idea. I just don't see people here or anywhere complaining much about actual failures.
The Following User Says Thank You to EAGLE5 For This Useful Post:
timurrrr (05-16-2021)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
