Old 04-22-2021, 09:49 AM   #4047
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
So the move is to put the crash bolts in the upper hole?
Cephas is offline   Reply With Quote
Old 04-22-2021, 10:06 AM   #4048
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's probably the cheapest way to add 2+° camber up front.
You are moving the top of the wheel closer to the strut by moving the nuckle inwards.
Some high offset wider wheels with wide tires will get close or rub. Something to consider.
Old 04-23-2021, 12:59 PM   #4049
marco_mc22
Drives: Toyota 86
Cheapest way to raise rear roll center is by upper control arms offset bushings, just a little variation tho, then you can raise the subframe height using special solid mounts, spl makes some solid mounts with special spacers to adjust roll center, but the more you raise the subframe the more your anti dive will increase at the same time your roll center will raise so it’s a matter of balance.
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
chuckdest (04-23-2021)
Old 04-23-2021, 03:03 PM   #4050
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by chuckdest View Post
Hi guys, I had a few questions about the roll centers on the FRS. (Please correct any of this it is wrong)
Stock Center of Gravity Height: 18.0"
Front Roll Center Height: 3.1"
Rear Roll Center Height: 3.8"
The things I have read said that a good place to set your roll centers for RWD cars is:
Front: 30% Height of Center of Gravity = 5.4"
Rear: 15% Height of Center of Gravity = 2.7"
My question is, why are the factory specs so far away from what I have read to be optimal??
If I am replacing all of my struts, springs, sways, wheels, tires and adjusting all of my alignment specs...Where should I try to set the roll centers?
For the front, I think the whiteline kit plus ride height tuning should get me close.
But what about the rear? I cant seem to find any solutions for adjusting the rear roll center outside of ride height.
Because this is a mass produced road car.
RayRay88 is offline   Reply With Quote
Old 04-26-2021, 12:02 PM   #4051
Cephas
Cephas's Avatar
Hey so I am le dumb.
Went to install some Cusco steering rack bushings. MacGyvered the stock ones out with a C clamp and some PVC. Figured the new ones were so tight, no WAY they'd go in crooked. Went to press them in with the PVC, and nope... Definitely went in crooked, and ruined the frame-side bushings in the process. <facepalm>
Lesson learned. Ordered the Cusco install tool along with a fresh set of bushings.
Question is, do y'all put a dab of grease on the metal sleeve insert to ease install, or just ram it in dry, so to speak?
Old 04-26-2021, 01:14 PM   #4052
Ohio Enthusiast
Drives: 2018 BRZ
I got grease together with the bushings (mine are Energy Suspension) and used it. Don't really see an issue with greasing them.
BTW, I MacGyvered a tool, same as the Cusco one, from a PVC pipe and a long threaded rod with some nuts and washers. Didn't really see a reason to pony up their asking price for the tool on top of the bushings.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Cephas (04-26-2021), CSG Mike (04-26-2021)
Old 05-03-2021, 10:20 AM   #4053
Jchang
Drives: 2018 Subaru BRZ Ts
A friend gave me his old set of RCE Yellows and I was wondering if it is worth swapping out the stock tS springs since they are upgraded springs already? I currently use the car as a daily and occasional autocross.
Jchang is offline   Reply With Quote
Old 05-03-2021, 01:50 PM   #4054
Racecomp Engineering
Just a little bit lower and stiffer with the Yellows. Noticeable in autox but up to you if it's worth it!
- Andrew
CSG Mike (05-03-2021), Jchang (05-04-2021)
Old 05-03-2021, 02:27 PM   #4055
Vital
Drives: 2015 BRZ
Honestly, id put the RCE Yellows on they are great. I have them and love mine i dont have a tS tho...
The Following 2 Users Say Thank You to Vital For This Useful Post:
Jchang (05-04-2021), Racecomp Engineering (05-03-2021)
Old 05-11-2021, 10:15 AM   #4056
ninzuh
Just wanted to give a quick thanks to everyone in this thread for the advice on refreshing my suspension, especially @Racecompengineering.
Yellows w/ fresh 17+ dampers is a great, budget friendly OEM+ route.
ninzuh is offline   Reply With Quote
The Following User Says Thank You to ninzuh For This Useful Post:
Racecomp Engineering (05-11-2021)
Old 05-11-2021, 02:32 PM   #4057
N_Raged
Drives: 2019 BRZ Sport-Tech RS
tS springs and Bilstein B6 ride height
Hello, I installed tS springs and B6 dampers myself and the rear ride height looks really high - higher than stock PP setup, even after alignment. Rear camber is only -0.8* and -1.0*. Do the springs just need more time to settle?
Ride height measurements with 225/45R17 tires, a half tank of fuel, and spare tire present in the trunk:
FL 26 5/8"
FR 26 3/8"
RL 27 1/16"
RR 27 3/8"
I read some things on this forum about spring orientation does not matter, but I oriented the spring perches the same direction as my stock suspension.
Unfortunately I don't have any previous ride height measurements to compare, so here's a photo of my stock setup for what it's worth.
N_Raged is offline   Reply With Quote
Old 05-11-2021, 03:35 PM   #4058
RToyo86
RToyo86's Avatar
The B6 have higher pressure which probably causes ride height to sit a bit higher.
I didn't take measurements either but visually the RCE yellow/B6 combo I have looks a touch taller than yellow/stock damper.
Old 05-11-2021, 05:05 PM   #4059
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I put ts springs and dampers on my MY13 and had the same result. Before and after measurements showed a definite increase in the rear by 3-5mm. Didn’t like it at first, but I gotta admit the thing rotates well.
BlueWhelan is offline   Reply With Quote
Old 05-11-2021, 06:17 PM   #4060
N_Raged
That's what I was afraid of, but the fronts look normal like photos of actual tS' from the factory. The rear is a whole inch higher than the front with enough fender gap for my fist lol.
That could just be due to old tired suspension sagging over time.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
