#77561 |
Technically, that's not true. An electric motor does not produce the same amount of torque from 0 to full speed, it's just flatter than ICE and it's harder to build a transmission for it.
Tesla originally had planned a two-speed transmission that would not only improve launch speeds but add range. Here's a good article that discusses it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Capt Spaulding (05-12-2021), Spuds (05-12-2021) |
#77562 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
How about "all the torque" at zero rpm? Not to mention the absence of valves to float, rods to break, rod bearings to spin and a host of indignities that ICEs weigh us down with. EVs just weigh us down with batteries. ![]() If so, put a 400 hp electric motor in front of a GM PowerGlide and it would be off faster than the Seattle real-estate market. BTW: that was an awfully young Jason Fenske in the video in the article. Actually, I'm just doing my best imitation of an EV fanboi. But, it's where we're going and, as much as I've enjoyed 60 years of building, racing, and breaking (rinse/repeat) IC engines, I'm sorta looking forward to it.
Slow is smooth, and smooth is fast
| The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post: |
#77563 | |
Chevy should take the Bolt, ramp up the power and make a sports coupe (instead of, ugm whatever the current one would be called) out of it. They could even reuse a name from the past and call it a chEVette.
| The Following User Says Thank You to Dadhawk For This Useful Post: | p1l0t (05-13-2021) |
#77564 |
The Dictater
Drives: '13 Red Scion FRS
The problem with BEVs is that the maximum power output is directly limited by battery capacity. There is a %discharge/time limit.
| The Following User Says Thank You to Spuds For This Useful Post: | Dadhawk (05-12-2021) |
#77565 |
Drives: Crapcan
Me calling the tire shop:
Yeah, I uh, need two sets of tires mounted and balanced for my 82’ Chevy Celebrity. I’ll just be dropping off the wheels and tires. ![]() ![]() Sent from my iPhone using Tapatalk
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | bcj (05-13-2021), Capt Spaulding (05-12-2021), p1l0t (05-13-2021), Sapphireho (05-13-2021), soundman98 (05-12-2021) |
#77566 | |
You won't be able to break it but it won't go fast.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: | Capt Spaulding (05-12-2021), Dadhawk (05-12-2021), ScoobsMcGee (05-12-2021), soundman98 (05-12-2021) |
#77567 | |
Junior Senior with Cheese
| The Following User Says Thank You to ScoobsMcGee For This Useful Post: | Capt Spaulding (05-12-2021) |
#77568 | |
Persona Non Grata
edit: It would be ideal with the torque curve of an electric motor.
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | Tcoat (05-12-2021) |
#77569 |
Persona Non Grata
@Scoobs Thanks mucho for the video. It was a lot of fun and brought back memories of the 70s.
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | ScoobsMcGee (05-12-2021) |
#77570 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Capt Spaulding (05-12-2021) |
#77571 | |
Random question that doesn't really fit a subforum.
Yesterday I drove through a parking garage in the middle of the day with my lights set to auto. So in the dark garage they turned on, and when I exited it to park outside in the bright sunlight it took forever for the lights to automatically turn off, such that backing into a space was a pain in the ass because bright sunlight + head unit set to dim when lights are on + back of the space in shadow. But I remember when I rented 86's in Japan and would drive through tunnels on the expressway the lights would turn off nearly immediately upon exiting into sunlight. Do different countries spec their light sensitivities differently for auto lights?
Instagram: @spike.grc
#77572 |
ProCrastinationConsultant
i don't think so. just generally differences in the sunlight angle. if the sun was setting, it'd create a shadow on the sensor, which would keep the lights on.
#77573 |
The Dictater
Also might depend on how long the lights were on in the first place.
#77574 | |
by the time i'd be done patching it, it'd be a 96,97,00,02,05 ranger...
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
