Old 05-12-2021, 12:22 PM   #77561
Originally Posted by Capt Spaulding View Post
EV = all the torque - all the time
Technically, that's not true. An electric motor does not produce the same amount of torque from 0 to full speed, it's just flatter than ICE and it's harder to build a transmission for it.
Tesla originally had planned a two-speed transmission that would not only improve launch speeds but add range.
Here's a good article that discusses it.
Dadhawk is offline
Capt Spaulding (05-12-2021), Spuds (05-12-2021)
Old 05-12-2021, 01:10 PM   #77562
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
OK, OK. Not all the time. But will you give me "most of the torque, most of the time?" How about "all the torque" at zero rpm? Not to mention the absence of valves to float, rods to break, rod bearings to spin and a host of indignities that ICEs weigh us down with. EVs just weigh us down with batteries.
If so, put a 400 hp electric motor in front of a GM PowerGlide and it would be off faster than the Seattle real-estate market.
BTW: that was an awfully young Jason Fenske in the video in the article.
Actually, I'm just doing my best imitation of an EV fanboi. But, it's where we're going and, as much as I've enjoyed 60 years of building, racing, and breaking (rinse/repeat) IC engines, I'm sorta looking forward to it.
Slow is smooth, and smooth is fast
Capt Spaulding is offline
The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post:
Dadhawk (05-12-2021), p1l0t (05-12-2021), Tcoat (05-12-2021), Ultramaroon (05-12-2021)
Old 05-12-2021, 01:24 PM   #77563
You got it. I'm slowly coming around.
Chevy should take the Bolt, ramp up the power and make a sports coupe (instead of, ugm whatever the current one would be called) out of it.
They could even reuse a name from the past and call it a chEVette.
Dadhawk is offline
p1l0t (05-13-2021)
Old 05-12-2021, 01:44 PM   #77564
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The problem with BEVs is that the maximum power output is directly limited by battery capacity. There is a %discharge/time limit.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Old 05-12-2021, 02:42 PM   #77565
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Me calling the tire shop:
Yeah, I uh, need two sets of tires mounted and balanced for my 82’ Chevy Celebrity. I’ll just be dropping off the wheels and tires.
NoHaveMSG is offline
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (05-13-2021), Capt Spaulding (05-12-2021), p1l0t (05-13-2021), Sapphireho (05-13-2021), soundman98 (05-12-2021)
Old 05-12-2021, 02:45 PM   #77566
BULL There is nothing you can put in front of a Power Glide that will make it go fast! NOTHING!!
You won't be able to break it but it won't go fast.
Tcoat is offline
Capt Spaulding (05-12-2021), Dadhawk (05-12-2021), ScoobsMcGee (05-12-2021), soundman98 (05-12-2021)
Old 05-12-2021, 03:21 PM   #77567
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Does this count? Just ignore the fact that the Power Glide later ended up spewing oil from the dipstick and would have burnt the thing to the ground had it not been for a suppression system.
ScoobsMcGee is offline
Old 05-12-2021, 03:23 PM   #77568
Capt Spaulding
Persona Non Grata
I beg to differ. A fella I knew in Houston in the late 60s-early 70s had a Chevy II running I don't remember what through a powerglide. He had survived polio and wasn't going to be pushing any clutches but it didn't matter. That car was one of the hottest street racers of the time.
edit: It would be ideal with the torque curve of an electric motor.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Tcoat (05-12-2021)
Old 05-12-2021, 03:44 PM   #77569
Capt Spaulding
Persona Non Grata
@Scoobs Thanks mucho for the video. It was a lot of fun and brought back memories of the 70s.
Old 05-12-2021, 04:04 PM   #77570
LOL I was being facetious. Although the saying wasn't "slip and side with powerglide" due to the speeds you could hit! I ran one in a couple of cars.
Tcoat is offline
Old 05-12-2021, 04:18 PM   #77571
spike021
spike021's Avatar
Random question that doesn't really fit a subforum.
Yesterday I drove through a parking garage in the middle of the day with my lights set to auto. So in the dark garage they turned on, and when I exited it to park outside in the bright sunlight it took forever for the lights to automatically turn off, such that backing into a space was a pain in the ass because bright sunlight + head unit set to dim when lights are on + back of the space in shadow.
But I remember when I rented 86's in Japan and would drive through tunnels on the expressway the lights would turn off nearly immediately upon exiting into sunlight.
Do different countries spec their light sensitivities differently for auto lights?
Instagram: @spike.grc
spike021 is offline
Old 05-12-2021, 05:26 PM   #77572
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't think so. just generally differences in the sunlight angle. if the sun was setting, it'd create a shadow on the sensor, which would keep the lights on.
soundman98 is offline
Old 05-12-2021, 05:28 PM   #77573
Spuds
The Dictater
Spuds's Avatar
Also might depend on how long the lights were on in the first place.
Spuds is offline
Old 05-12-2021, 05:28 PM   #77574
soundman98
soundman98's Avatar
That's why I don't sell my old vehicles, ever. I drive them until they aren't worth fixing anymore and then I just get rid of them. People are such a PITA.
i was really close to doing that with this truck. problem is the rust--it creeps in faster than i have time to patch it. it's a losing game of catchup
by the time i'd be done patching it, it'd be a 96,97,00,02,05 ranger...
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
p1l0t (05-14-2021), Spuds (05-12-2021), Ultramaroon (05-12-2021)
