Old 05-09-2021, 09:01 PM   #1
chopper86
Drives: 2017 Toyota 86 860 Special Edition
Exclamation P0560 - System Voltage Malfunction
All fixed now, the car was missing the EFI B+ fuse for whatever reason.
A couple of months ago my 2017 86 died after about an hour or two of sitting. I jump started it and since then the CEL (p0560) has been on. I took it to a Toyota dealership and they replaced the battery, and that was about it. They said they wanted to put a new computer in it costing me $3,000, so I did the reasonable thing and took my car back. The only thing different that I have noticed since the incident is when downshifting (automatic) the car slowly revs back up and slows way down, compared to before the car died, it would simply just rev up and continue going the same speed, was very smooth. I have tested the alternator and battery and voltage is normal. I have been looking online and the only thing I can come up with is ECM or PCM issues. I will be taking it to a local shop soon, but was wondering if anyone has had this issue before and how they fixed it.
chopper86 is offline   Reply With Quote
The Following 2 Users Say Thank You to chopper86 For This Useful Post:
humfrz (05-10-2021), soundman98 (05-10-2021)
Old 05-10-2021, 12:59 AM   #2
Welcome to the group, chopper86 -
Since you have replaced the battery, the next thing I'd suggest you take a careful look at is the alternator and have it checked out.
After you replaced the battery, did the p0560 code go away and has it stayed away?
Good luck.
Old 05-10-2021, 01:13 AM   #3
chopper86
Good luck.
The alternator reads normal voltages idle and under load, and all of the electronic accessories have been working perfectly.
I am currently still stuck with the p0560 code, its the same code from the start and cant seem to shake it.
The Following User Says Thank You to chopper86 For This Useful Post:
humfrz (05-10-2021)
Old 05-10-2021, 06:05 AM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The circuit for that dtc is literally one wire with two fuses on it. Since the car is working we can assume the MAIN fuse is ok, that leaves the EFI B+ fuse.
Old 05-10-2021, 11:21 AM   #5
chopper86
Just went and check and I guess the Toyota dealer removed that fuse for whatever reason. Popped the right fuse in and shifting is back to normal and CEL is cleared. Thanks for the help man, I've been stuck with this code for months and you saved me the money and time taking it to a shop would cost.
humfrz (05-10-2021)
Old 05-10-2021, 05:09 PM   #6
RZNT4R
Many times I've had cars brought to me with complaints of accessories being inop, quite a few times it's been a missing fuse. Not blown, m i s s i n g.
It's entirely possible that your car may have died for an unknown reason and that a jump starting mishap blew it, the dealer might have taken it out to run tests with a fuse saver (handheld circuit breaker at the end of a long extension) and when faced with being unable to replicate the issue that blew it,said f*ck it, thrown an ecm at it and just didnt replace the blown fuse.
if it blows again out of nowhere you'll know you've got a real issue.
The Following User Says Thank You to RZNT4R For This Useful Post:
Old 05-16-2021, 05:42 PM   #7
p1l0t
p1l0t's Avatar
Haha or you know stealership...
Ultramaroon (05-17-2021)
O2S2 Voltage Always Zero bhaugen2 Engine, Exhaust, Transmission 22 09-14-2022 05:35 AM
help - voltage oscillates Last Lemming Alive BRZ First-Gen (2012+) — General Topics 29 04-10-2022 08:37 PM
Charging system voltage drops low occasionally ChrisW Electronics | Audio | NAV | Infotainment 11 11-27-2017 08:52 AM
URGENT - Engine Immobilizer System Malfunction! KevinTJH Scion FR-S / Toyota 86 GT86 General Forum 18 09-29-2013 12:52 PM
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 08:15 PM
