#813 | |
ProCrastinationConsultant
| The Following User Says Thank You to soundman98 For This Useful Post: | Tcoat (04-20-2021) |
#814 | |
Military aircraft have the standards lights on them (at least the ones I've seen) you just run dark when you don't need them.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Kaotic Lazagna (04-20-2021) |
#815 |
May be a tad heavy for the purpose.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (04-20-2021) |
#816 |
So there is a lot of skepticism on the modeling forum that I can pull off the damaged aircraft.
It is relatively easy really since nothing looks quite like torn an buckled aluminum as torn and buckled aluminum. It is just a matter of replacing the the plastic with appropriate materials.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#817 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Since you're doing the painting, make it a nude beach?
Or would that make the pommie model crew blow a gasket?
"I gotta rock." -- Charley Brown |
#818 | |
In the smaller scales (1/72 & 1/48) you can usually hardly see the panel anyway so lighting it up would only work on certain aircraft. This works but it is a lot of trouble for a few lights. https://www.deviantart.com/davidssca...hted-866733044
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (04-20-2021) |
#819 |
Sure then I need to do 1/50th scale pubic hair!
| The Following User Says Thank You to Tcoat For This Useful Post: | bcj (04-20-2021) |
#820 |
No going back now!
Everything that needs to be mangled, missing or moved cut off. Spent a couple of hours effectively doubling the parts count in the kit.
#821 |
Drives: GR Corolla
Switched over from the lighting to starting to polish the body. Started with the hood, and calling it a day. Wet sanded with 2000 grit, the. 2500, then toothpaste, then, CG V36, then V38, and oddly enough, Meguiar's Scratch X since the CG V38 didn't really give a good final polish (that's why I don't use them on my real car).
Not bad for just Tamiya cans. =) First picture is the reflection of my window. Can see the window screen! Second pic is showing the reflection of the JBL logo. |
#822 |
Drives: GR Corolla
The hood started out similar to the rest of the body as seen here.
| The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post: |
#823 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#824 |
Still struggling with interior colours.
This is a newer version (and a restore) that shows the green on main components and yellow on secondary. ![]() An enhanced picture of the damaged section does show what appears to be a darker colour on the main with lighter colours (arrows) on secondary.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (04-24-2021) |
#825 |
Drives: GR Corolla
#826 |
That is why I rarely do cars.
| The Following User Says Thank You to Tcoat For This Useful Post: | Kaotic Lazagna (04-23-2021) |
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
