Old 04-19-2021, 11:40 PM   #813
soundman98
ProCrastinationConsultant
soundman98's Avatar
That is what I am thinking. The only reason I didn't just go ahead and do it was that getting to the stuff means moving and digging through about 12 big boxes to find it.
Not like I can run down to the store for Christmas decorations in mid April. That is if the stores were even open! I could use cotton balls but even pulled apart they are denser than I want.
if you didn't live so far away, i know exactly where my box of polyfil is, could have as much as you want!
Tcoat (04-20-2021)
Old 04-20-2021, 07:25 AM   #814
Originally Posted by Kaotic Lazagna View Post
Instrument panel would be cool, but how would you back light a decal (assuming a decal is used)? That's one reason why I never attempted to put lights behind the gauges in the car models. Lol
Do these fighter planes even have those external lights listed? Would have thought they wouldn't want any lighting on the exterior to make it more difficult to see. Then again, I know nothing when it comes to planes.
I could see doing it by inserting a thin clear sheet behind it, then blacking out the portions not behind an instrument. You would backlight the plastic and it should show through the decals. It would be difficult of course.
Military aircraft have the standards lights on them (at least the ones I've seen) you just run dark when you don't need them.
Kaotic Lazagna (04-20-2021)
Old 04-20-2021, 07:26 AM   #815
May be a tad heavy for the purpose.
soundman98 (04-20-2021)
Old 04-20-2021, 07:31 AM   #816
So there is a lot of skepticism on the modeling forum that I can pull off the damaged aircraft.
It is relatively easy really since nothing looks quite like torn an buckled aluminum as torn and buckled aluminum. It is just a matter of replacing the the plastic with appropriate materials.
Dadhawk (04-20-2021), NoHaveMSG (04-20-2021), soundman98 (04-20-2021), Spuds (04-20-2021)
Old 04-20-2021, 11:28 AM   #817
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Since you're doing the painting, make it a nude beach?
Or would that make the pommie model crew blow a gasket?
Old 04-20-2021, 11:40 AM   #818
Actually be pretty easy in larger scales.
In the smaller scales (1/72 & 1/48) you can usually hardly see the panel anyway so lighting it up would only work on certain aircraft.
This works but it is a lot of trouble for a few lights.
https://www.deviantart.com/davidssca...hted-866733044
Old 04-20-2021, 11:42 AM   #819
Sure then I need to do 1/50th scale pubic hair!
bcj (04-20-2021)
Old 04-21-2021, 08:05 PM   #820
No going back now!
Everything that needs to be mangled, missing or moved cut off.
Spent a couple of hours effectively doubling the parts count in the kit.
bcj (04-22-2021), Dadhawk (04-23-2021), Kaotic Lazagna (04-22-2021), soundman98 (04-21-2021)
Old 04-22-2021, 08:17 PM   #821
Kaotic Lazagna
Drives: GR Corolla
Switched over from the lighting to starting to polish the body. Started with the hood, and calling it a day. Wet sanded with 2000 grit, the. 2500, then toothpaste, then, CG V36, then V38, and oddly enough, Meguiar's Scratch X since the CG V38 didn't really give a good final polish (that's why I don't use them on my real car).
Not bad for just Tamiya cans. =)
First picture is the reflection of my window. Can see the window screen! Second pic is showing the reflection of the JBL logo.
The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Dadhawk (04-23-2021), Spuds (04-22-2021), Tcoat (04-23-2021)
Old 04-22-2021, 08:26 PM   #822
Kaotic Lazagna
Drives: GR Corolla
The hood started out similar to the rest of the body as seen here.
Dadhawk (04-23-2021), soundman98 (04-22-2021), Tcoat (04-23-2021)
Old 04-23-2021, 07:38 AM   #823
And that is why 99.2% of my paints are flat!
Dadhawk (04-23-2021), Kaotic Lazagna (04-23-2021), soundman98 (04-23-2021)
Old 04-23-2021, 08:11 AM   #824
Still struggling with interior colours.
This is a newer version (and a restore) that shows the green on main components and yellow on secondary.
An enhanced picture of the damaged section does show what appears to be a darker colour on the main with lighter colours (arrows) on secondary.
Ultramaroon (04-24-2021)
Old 04-23-2021, 10:09 AM   #825
Kaotic Lazagna
Drives: GR Corolla
I don't like matte finishes for cars tho (some exceptions).
Old 04-23-2021, 10:19 AM   #826
That is why I rarely do cars.
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
