#15 |
Drives: '13 Whiteout
Aside from the tire wear how is the handling balance?
#16 | |
2013 Series 10 FRS #553
#17 | |
Drives: '13 FRS - STX
https://photos.app.goo.gl/raGSjKQ6Bx9amELP9 |
| The Following User Says Thank You to strat61caster For This Useful Post: | Petah78 (04-19-2021) |
#18 |
Drives: '23 BRZ
I only did 4 events last year, and ran my street tires on day one of each event. With 4 track days on my street tires (245/40-17 Conti ECS) and ~5000 street miles, all at -3.5 front camber, I have even wear across the treads. I did rotate between each track event.
#19 |
Be aware not all tires are able to rotate in a front to back opposite sides
#20 |
I got about 15k miles out of my firestones but they were probably due to be replaced at 10k miles and were sketchy as fuck at the end, alignment varied throughout.
Big change if you're used to getting 60k miles out of your daily tires... It's all perspective. |
#21 | |
Drives: '23 BRZ
As for left/right, directional tires *can* be driven in the "wrong" direction without issue. I've done it many times. Tests have shown that running directional tires backwards pretty much doesn't make any difference even in standing water. From what I've read a lot of times the directional pattern is more about noise than actual water-handling or hydroplaning resistance. That said, for *street* usage rotating front/back is fine. However for multiple track days at the same track, you'll want to do the normal rwd tire rotation pattern (or any pattern really that ensures each tire winds up at each corner of the car on a regular basis). |
| The Following User Says Thank You to ZDan For This Useful Post: | jflogerzi (04-19-2021) |
| How does my tire wear look? | R_E_L | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2018 08:34 AM |
| tire wear | oppiee | Tracking / Autocross / HPDE / Drifting | 9 | 08-29-2017 01:55 PM |
| Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 04:19 PM |
| Tire Wear Help | babykwiss | Tracking / Autocross / HPDE / Drifting | 10 | 07-14-2014 12:31 PM |
| Let's Discuss Tire Wear | SkitterSkotter | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-15-2014 12:35 AM |
