Drives: 2014 Scion FRS (Red)
tire wear
Hey guys,
I was at the track this weekend. I wanted to get some opinions on seasoned track day goers. I noticed that my front tires had a lot of wear on tread just adjacent to the tire wall. like piece were chewed off. Nothing on my rear tires. Do you guys think i am over driving or is this just normal for this car? Thanks!! |
Probably need more negative camber up front. What is your alignment?
2022 BRZ Build 2013 FR-S Build |
Drives: BRZ 2017 Pure Red, MT
What is your front camber?
What tire model? What pressure were you running (specify if hot or cold psi). |
Drives: Car
What tires were you running? Sounds like they're chunking. You got any pics?
If your car is totally stock (suspension wise at least) and you were attempting to drive it at 10/10ths it's totally expected for this to happen. The car lacks enough camber up front due to the Macpherson strut design.
Find a way to add camber that suits you and get it aligned to reduce tire wear up front. As an added bonus you'll have a lot more front end grip in steady state cornering which should lead to a more balanced fun car imho. Based on my limited experience I think -2.5 degrees would be a more aggressive compromise between track and street, -3.0 and you're getting close to evening out the wear. Less may be workable depending on what you want out of the car and your driving style and what you want to spend on modifying it for track use (camber bolts vs. camber plates vs. slotted struts). http://www.ft86club.com/forums/showthread.php?t=103609 Order the parts, schedule an alignment, swap the tires back to front and head out to your next track day! And keep an eye on the brakes if those are still stock too, those will be the next to go (if they haven't already)
#6 | |
Drives: 15 BRZ LTD, 05 FXT
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post: | oppiee (08-29-2017), strat61caster (08-28-2017) |
#7 | |
Thanks! Ya I am running fully stock suspension wise.
running continental extreme contact. how much will camber bolts help? pic is here: https://goo.gl/photos/EZKXHA6x3vyc6T83A Quote:
#8 | ||
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Either you manage the tires (slow in, manage mid corner) or increase camber. I now have -3.2 and its JUST right based on tire temps. Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
| The Following User Says Thank You to lutfy For This Useful Post: | strat61caster (08-29-2017) |
#9 | |
Thats fair.
I just got into tracking the car this year. So i am still learning. I will eventually get coilovers and whatever I need to make things better. just wanted to make sure this is normal haha! I want to increase my time on the track and get better lap times and slowly upgrade. Quote:
#10 | |
Like @lufty says, you're only going to get about -2.0 to -2.5 this way, it will help a noticeable amount but you will still see outer shoulder wear. imo rotate the tires and keep driving hard, it's all part of learning ![]() Edit: oh, and here's what my tires looked like after my second track day |
| Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 04:19 PM |
| Strange tire wear | PandaBRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 04-18-2016 03:22 AM |
| Tire Wear question | bacon_cheese_beer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 12-08-2014 03:51 AM |
| Tire Wear Help | babykwiss | Tracking / Autocross / HPDE / Drifting | 10 | 07-14-2014 12:31 PM |
| Let's Discuss Tire Wear | SkitterSkotter | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-15-2014 12:35 AM |
