Old 04-07-2021, 10:43 PM   #29
sato
sato's Avatar
Drives: Dodge Patitas
@prandelia Any updates?
sato is offline   Reply With Quote
Old 04-08-2021, 02:01 AM   #30
jflogerzi
jflogerzi's Avatar
Originally Posted by Goingnowherefast View Post
Honestly, no I never have. To be honest, I think the fix would be a set of coilpacks like this: https://www.delicioustuning.com/node/959
In my head, coilpacks getting overheated is the issue. Having a ceramic coated or wrapped header may help this issue. (I'm still searching for a JDL 4-2-1). If i have more issues this year, I'm just gonna get those coilpacks and then report back!
Mike at csg mentioned these did not help.
2013 Series 10 FRS #553
Old 04-09-2021, 07:07 PM   #31
CSG Mike
CSG Mike's Avatar
More specifically, I recommend the IP Plasma. Skip their quad spark coil packs.
Old 04-10-2021, 01:59 PM   #32
DarkSunrise
DarkSunrise's Avatar
I’m testing a set of the Delicious coilpacks. Put them in today and fitment was good. Did a quick drive and no problems so far.
I drive mainly track (91 oct) and canyons (e85) with my FRS. My last cylinder 1 coilpack was OEM and lasted 2000 miles to give some context. In addition to a few cylinder 1 coilpacks, I’ve also had to replace a cylinder 2 coilpack.
I’ll update this thread with how these hold up. Delicious said they would consider making revisions based on my data so they seem pretty interested in offering a durable solution that will hold up to track/e85 use.
2022 BRZ Build
2013 FR-S Build
Old 04-10-2021, 08:44 PM   #33
jflogerzi
jflogerzi's Avatar
Why not run e85 at the track? No flex fuel?
Old 04-10-2021, 10:23 PM   #34
DarkSunrise
Yep no e85 near the track and I'm using a straight e85 tune.
2022 BRZ Build
2013 FR-S Build
Old 05-11-2021, 10:22 AM   #35
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Did you ever solve this. I picked up a couple of used coils as I got the P3051 this past weekend at the very top of 4th bouncing a bit off rev limiter. CEL only.
To update this, I believe my issues are now not coilpack related. My misfire/stuttering only happens at one specific track during a high G left hand turn. Thus, I'm thinking my problem will be solved with this: https://www.verus-engineering.com/sh...e=2&category=1
I've purchased this fuel door and will report back here if I get any luck. This may help others with a "misfire" like symptom.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 06-06-2021, 11:58 AM   #36
DarkSunrise
Things are going well with these Delicious red coilpacks. I'm at 2000 miles so at least these beat my last OEM coilpack replacement.
I logged for misfires on my canyon drive yesterday. Total driving time was 3.5 hrs. The canyon portion was entirely 4500-7500 rpm. Some highway cruising in the 3000-3600 rpm band. No misfires on cylinders 1-4. This is with a tweaked OFT E85 tune and oem 2017 header.
I've got a couple of track days coming up in the next 2 months. Will update afterwards.
2022 BRZ Build
2013 FR-S Build
Old 06-06-2021, 09:18 PM   #37
PulsarBeeerz
Drives: JRSC BRZ SOLD
I've run the Delicious tuning coilpacks along with NGK spark plugs for 5-6k so far. 93 and E85 no issues. They will see FI use here in the next couple months. I went through 3 OEM coilspack from 3 different cylinders. haha
PulsarBeeerz is offline   Reply With Quote
Old 07-25-2021, 11:26 AM   #38
DarkSunrise
Update on the Delicious red coilpacks:
The last two canyon days, I started seeing moderate FLKC (approximately -4 degrees) in the 6500-7500 RPM band in my logs under full load. Well today my engine finally threw a P0353 code in the canyons, so looks like the cylinder 3 coilpack went bad.
It's been 3.5 months / 3,200 miles since I put in these Delicious red coilpacks. Have been using E85 exclusively and probably a dozen fairly hard canyon days (245 F peak oil temps with Perrin oil cooler).
I'll contact Delicious on Monday and see what they recommend.
2022 BRZ Build
2013 FR-S Build
Old 10-16-2021, 01:25 AM   #39
DarkSunrise
Realized I forgot to update this thread. Delicious sent out a set of replacement coilpacks. These look slightly different than the first set. The black plastic changed from matte to shiny. There are green streaks inside the rubber tubing. The red plastic is a bit more orange. Not sure if these are just cosmetic differences or anything changed inside.
It’s too early to give any conclusions (only 1300 miles) but so far they’ve survived a track day at Buttonwillow on 91 octane and a few canyon days on e85. Hoping these will make it past 3200 miles.
2022 BRZ Build
2013 FR-S Build
Old 11-23-2021, 07:13 PM   #40
sato
sato's Avatar
Updates?
Old 11-27-2021, 08:15 PM   #41
DarkSunrise
Originally Posted by sato View Post
Updates?
No real updates on my end. I haven’t really been able to drive track/canyons much since #2 was born but so far these replacement Delicious coilpacks have held up.
2022 BRZ Build
2013 FR-S Build
Old 06-07-2022, 02:04 AM   #42
2013Track86
Drives: 2013 FRS
So, I did my first track day in my 2013 FRS yesterday. Ambient temps were pretty mild, at around 70 degrees. I logged oil temp and water temp via Torque, and saw oil temps in the 230 range at peak (I have an oil cooler) and water temps a hair above 200.
During my last session I had 2 issues with engine hesitation, both in the same place, at the top of 4th gear. It felt like the engine had died....no power at all. At first I thought it felt like a dropped valve and the engine was toast. No CEL. After a few seconds, the car picked back up again and felt totally normal. Is this likely a coil pack issue (see video below)?
Car has ~100k miles, and I have no idea if the coil packs (or plugs for that matter) have ever been changed. My plan is to replace the plugs and coil packs with the IP units, but want confirmation this is likely to help before spending the $$
2013Track86 is offline   Reply With Quote
Ignition system explaination? radroach Engine, Exhaust, Transmission 4 05-09-2016 06:03 PM
Fuel System upgrades protpibe Forced Induction 5 07-11-2014 12:07 PM
BRZ keyless entry/ignition and auto climte control system how-to video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 26 11-21-2013 01:58 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Aftermarket Push Button Ignition Smart Entry System zAnSh1n Electronics | Audio | NAV | Infotainment 75 08-19-2012 02:23 PM
