Old 07-11-2014, 10:23 AM   #1
protpibe
protpibe's Avatar
Fuel System upgrades
My clutch finally arrived so I'm going to upgrade my fuel system next. I'm currently running the AVO Turbo Kit (Stage whatever). My high map is currently set to 11psi with 94 octane. I would like to run a 15-16psi map, which I'm assuming is the ceiling for the AVO. From what I understand, the stock fuel system isn't up to the task so I'll be upgrading it.
I'm just looking for some feedback on the setup that I'm going with, just to confirm that it will fit the bill.
I'm planning on ordering a DW65c Fuel Pump and 700cc DW Injectors.
Are the injectors overkill, and would the 450's be sufficient? Is there another injector that I should consider? Delicious Tuning is taking care of the tune and they've said that I should go with an EV-14 injector. I live in the middle of Canada so a local tuner is out of the question.
Also, is there any reason that I should not go with the DW fuel pump and go with something like Aeromotive or AEM?
I would appreciate some insight! Thanks
Old 07-11-2014, 10:37 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Best solution for in-tank pump setup currently:
http://www.ft86club.com/forums/showthread.php?t=58756
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
protpibe (07-11-2014)
Old 07-11-2014, 10:42 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Are you continuing with 94 octane? If so, then 700cc injectors are definitely overkill. I also agree that I would probably stay away from the DW65c and go with the Full Blown Walbro kit.
The Following User Says Thank You to King Tut For This Useful Post:
Old 07-11-2014, 10:48 AM   #4
protpibe
protpibe's Avatar
Thanks for that link, it wasn't even on my radar.
And yeah, we don't have E85 up here so it will be 94. It sounds like 450cc would be enough
Old 07-11-2014, 10:49 AM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
im at 85% duty cycle with dw700's on e85 at 18psi on my avo kit. the kit is basically maxed so the injector size is good if you are running e85. for 93/94, you wont need that much.
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 07-11-2014, 12:07 PM   #6
protpibe
protpibe's Avatar
Unfortunately we don't have E85 anywhere, and I doubt we'll be betting it anytime soon. The cost of injectors is low enough that I'll go with 450's for now and if baby jesus ever blesses us with E85, I'll just upgrade.
Thanks for the info guys. I think I'll go with the FBM pump setup
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Fuel upgrades, when and what? diss7 Forced Induction 9 02-11-2014 03:18 PM
Boosted + Fuel Upgrades Ahmad-QTR Forced Induction 1 09-17-2013 07:31 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
