Drives: Toyota 86 2014 GTS
Hey so my transmission seems to be having problems. Don’t know where to start looking. It does it both in drive and manual mode. First gear to second gear full throttle, the gear takes a good 2 seconds to realise it needs to shift then it gets stuck and doesnt do anything until I lift my foot, then it’ll continue climbing speed and rpm. as you can see in the video attached. No idea what the cause is. then second to third it does like a weird jump when I change to third, when I shift at heavy load. Any ideas guys? Cheers. By the way! The car shifts like butter when first started / cold. Goes crazy at warm operating temp
#2 |
Have you changed the fluid at all? Really basic question I know but the difference between cold and hat shifting sounds like fluid breakdown.
#3 |
Car had a 90,000km major service, and during that service, all the fluids and oils got replaced. The problem still persisted after that service with the new fluid
| The Following User Says Thank You to Biggumzzz For This Useful Post: | Tcoat (04-09-2021) |
#4 |
Well that does rule out the easy one then.
#5 |
#6 |
Problem has been found. Clutch bands were absolutely stuffed.. fluid went black after replacement in a week... definitely a dud now.. got a whole transmission replacement and the car runs like new.
| Shifting Problem (Automatic) | FRSure | Issues | Warranty | Recalls / TSB | 61 | 05-09-2021 07:38 PM |
| Please help me diagnose a shifting problem | Pat | Engine, Exhaust, Transmission | 22 | 08-05-2019 03:30 PM |
| Problem Shifting into gears. | itzryry | Issues | Warranty | Recalls / TSB | 6 | 01-25-2018 07:19 PM |
| Gear shifting | TexasFRS | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 05-11-2016 10:29 PM |
| Shifting from 1st-2nd gear... | FRSpappa | Engine, Exhaust, Transmission | 13 | 05-24-2014 10:06 PM |
