Old 04-05-2021, 11:21 PM   #18999
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by Breezio View Post
It should be fine if you keep oem over pipe and front pipe.
I have the old OpenFlash UEL catless header, oem over pipe and front pipe. It's not too loud. My tune does have a reduced cold start idle so I can't speak for that particular portion.
Here is what she sounds like at full tilt, microphone is attached at the rear license plate.
Nice run, man! Had a little happy dance goin’ there at the end
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Breezio (04-06-2021)
Old 04-06-2021, 12:58 AM   #19000
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Thanks! Yeah, that run just barely edged me into 3rd PAX out of 75ish drivers, many of which are very talented and very fast. Plus the car felt great all day with real nice controllable mid-corner on throttle rotation.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
BrahmaBull1990 (04-06-2021)
Old 04-06-2021, 12:43 PM   #19001
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Over the course of this weekend...
Swapped back to summer wheels.
Installed OEM Side window visors (P/N: 0816218810)
Full interior & exterior detail.
Waxed with Soft99 Fusso Coat 12 months Dark.
Carpro Flyby Forte to all glass.
Carpro DLUX to all trim & wheels.
wolffbite is offline   Reply With Quote
The Following 5 Users Say Thank You to wolffbite For This Useful Post:
beltax90 (04-07-2021), BrahmaBull1990 (04-06-2021), Breezio (04-07-2021), juenedgi (04-08-2021), Stonehorsw (04-06-2021)
Old 04-06-2021, 06:22 PM   #19002
bart2ooo
Drives: 2019 BRZ Limited PP
Car sounds awesome! And sick run man!
bart2ooo is offline   Reply With Quote
The Following User Says Thank You to bart2ooo For This Useful Post:
Old 04-07-2021, 08:03 PM   #19003
Mtl135i
Drives: BMW 135i
Out for the summer 😁
Mtl135i is offline   Reply With Quote
The Following 4 Users Say Thank You to Mtl135i For This Useful Post:
beltax90 (04-07-2021), BrahmaBull1990 (04-07-2021), juenedgi (04-08-2021), soundman98 (04-07-2021)
Old 04-07-2021, 10:28 PM   #19004
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Not my car but such an EPIC V8 swap on a twin...I’m shocked tbh
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
NoHaveMSG (04-08-2021), soundman98 (04-07-2021)
Old 04-08-2021, 12:33 AM   #19005
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Changed the gearbox and dif oils
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
BrahmaBull1990 (04-10-2021), NoHaveMSG (04-08-2021)
Old 04-08-2021, 09:09 PM   #19006
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Manicci mats and new sills/scuffs from Subispeed.
Not 100% sure how I feel about the Aero Fins...
Renegade Motorsports cap kit to rid the bay of all the yellow caps, APR shroud, and some Cusco fanboi bits and pieces.
Swapped the Sachs/Eibach out with the CSG Tein FLA kit. Also installed the ARP OEM length studs. CSGs come with very little, if any, adjustments needed. I did two rounds of minute tweaking at each corner based on my weight etc. and had Street Automotive in Reno take over for the final fine tuning of camber/caster/et al and alignment.
therealstoly is offline   Reply With Quote
The Following 3 Users Say Thank You to therealstoly For This Useful Post:
beltax90 (04-12-2021), norcalpb (04-09-2021), wolffbite (04-09-2021)
Old 04-09-2021, 01:46 PM   #19007
spike021
spike021's Avatar
Yesterday got the car back from the shop.
Had:
* TOB and clutch fork replaced with new 2017+ TOB, Verus fork/pivot
* Jackson Racing combo oil cooler/radiator
Can't wait to see how everything feels and works!
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
Wally86 (04-12-2021)
Old 04-09-2021, 02:17 PM   #19008
wolffbite
Just the tip
wolffbite's Avatar
Had:
How many miles on your TOB before it crapped out?
Old 04-09-2021, 02:44 PM   #19009
spike021
spike021's Avatar
I’m at about 47,000 right now.
The thing to keep in mind is I learned manual on this car so I probably put those bits through a bit of a beating the first few thousand miles.
I’ve had different kinds of TOB noises for probably a year or so already (past 10k or so miles). Mostly like marble rolling around type noises that went away if I pushed in the clutch. Also some difficult shifting even with recent trans fluid changes.
About a month ago I started getting some intermittent higher pitched whirring/buzzing noises that came and went, but would go away if I clutched in too.
So I figured I should just get it swapped out. It could’ve been a little early too but I wanted to be safe.
Old 04-09-2021, 03:20 PM   #19010
Grady
Grady's Avatar
Originally Posted by therealstoly View Post
I don’t understand? Are dipsticks flying out of these engines?
The Following 5 Users Say Thank You to Grady For This Useful Post:
BrahmaBull1990 (04-10-2021), DarkPira7e (04-09-2021), NoHaveMSG (04-09-2021), soundman98 (04-09-2021), spike021 (04-09-2021)
Old 04-09-2021, 03:32 PM   #19011
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Had:
I also had my TOB replaced at 50k miles with the same parts.
Definitely recommend getting it done sooner than later!
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following User Says Thank You to KMA KiCKz For This Useful Post:
Old 04-09-2021, 06:08 PM   #19012
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Any benefit for Tein coilover compared to Sachs/Eibach?
Stonehorsw is offline   Reply With Quote
