Old 03-29-2021, 08:46 PM   #18999
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by Breadman View Post
so i took most of the stuff apart and found a nice hole on the cam covers on one side. so i dropped the pan and its like sifting for gold. took off the oil pick up and found some strands of gasket maker in there.
my theory was avcs failed a retainer or cam then punched a hole and it sprayed all the oil out until the valve hit the piston and killed the engine. this makes sense because i lost power before a bang and the car hopped. also oil sprayed out of my passenger wheelwell. oh yeah they also resealed my heads because they were leaking 600 miles ago. calling the dealer and telling them they are fixing it. i have a blackstone for 800 miles ago and no wear metals
That’s crazy you had leaking heads with a 2017. The dealer better pay some of it (or all of it)
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-29-2021, 08:51 PM   #19000
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
they denied the leak for 3 months saying whoever changed my oil spilled it on the pan. then i braked cleaned everything and took it back and it was covered and they said it could be a bunch of things so i tracer dyed it then they tried to say i had a tune so they werent going to cover it and i pointed out it literally had nothing to do with oil.
The Following User Says Thank You to Breadman For This Useful Post:
BrahmaBull1990 (03-29-2021)
Old 04-02-2021, 05:21 AM   #19001
GaDgeT
GaDgeT's Avatar
Installed the Slambert Engineering Hitch and tow pack, loading, transport and life made so much easier..
GaDgeT is offline   Reply With Quote
The Following 5 Users Say Thank You to GaDgeT For This Useful Post:
beltax90 (04-03-2021), BrahmaBull1990 (04-05-2021), marky (04-08-2021), soundman98 (04-02-2021), vintagemxer (04-05-2021)
Old 04-02-2021, 07:53 AM   #19002
JD001
JD001's Avatar
Drives: Subaru BRZ
As was promised, I got the car taxed yesterday, pumped up the tyres and took it out for a drive.. this after 3 months of zero activity..
The Following 5 Users Say Thank You to JD001 For This Useful Post:
beltax90 (04-03-2021), BrahmaBull1990 (04-05-2021), Dadhawk (04-02-2021), soundman98 (04-02-2021), Ultramaroon (04-05-2021)
Old 04-05-2021, 08:40 AM   #19003
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Originally Posted by bart2ooo View Post
Is that the HKS Spec L2 Exhaust i see?
Yeah, HKS Hi-Power Spec-L
I love it, sounds great and very light for a stainless dual exit.
Breezio is offline   Reply With Quote
Old 04-05-2021, 12:12 PM   #19004
bart2ooo
Drives: 2019 BRZ Limited PP
Anything else done to the exhaust setup? I'm thinking about getting the Spec-L once i get my Tomei UEL but i'm not sure how loud it'll be as far as cold starts and neighbors lol
bart2ooo is offline   Reply With Quote
Old 04-05-2021, 10:29 PM   #19005
Breezio
Breezio's Avatar
It should be fine if you keep oem over pipe and front pipe.
I have the old OpenFlash UEL catless header, oem over pipe and front pipe. It's not too loud. My tune does have a reduced cold start idle so I can't speak for that particular portion.
Here is what she sounds like at full tilt, microphone is attached at the rear license plate.
The Following User Says Thank You to Breezio For This Useful Post:
Old 04-05-2021, 11:21 PM   #19006
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Nice run, man! Had a little happy dance goin’ there at the end
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Breezio (04-06-2021)
Old 04-06-2021, 12:58 AM   #19007
Breezio
Breezio's Avatar
Thanks! Yeah, that run just barely edged me into 3rd PAX out of 75ish drivers, many of which are very talented and very fast. Plus the car felt great all day with real nice controllable mid-corner on throttle rotation.
BrahmaBull1990 (04-06-2021)
Old 04-06-2021, 12:43 PM   #19008
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Over the course of this weekend...
Swapped back to summer wheels.
Installed OEM Side window visors (P/N: 0816218810)
Full interior & exterior detail.
Waxed with Soft99 Fusso Coat 12 months Dark.
Carpro Flyby Forte to all glass.
Carpro DLUX to all trim & wheels.
wolffbite is offline   Reply With Quote
The Following 5 Users Say Thank You to wolffbite For This Useful Post:
beltax90 (04-07-2021), BrahmaBull1990 (04-06-2021), Breezio (04-07-2021), juenedgi (04-08-2021), Stonehorsw (04-06-2021)
Old 04-06-2021, 06:22 PM   #19009
bart2ooo
Car sounds awesome! And sick run man!
The Following User Says Thank You to bart2ooo For This Useful Post:
Old 04-07-2021, 08:03 PM   #19010
Mtl135i
Drives: BMW 135i
Out for the summer 😁
Mtl135i is offline   Reply With Quote
The Following 4 Users Say Thank You to Mtl135i For This Useful Post:
beltax90 (04-07-2021), BrahmaBull1990 (04-07-2021), juenedgi (04-08-2021), soundman98 (04-07-2021)
Old 04-07-2021, 10:28 PM   #19011
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Not my car but such an EPIC V8 swap on a twin...I’m shocked tbh
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
NoHaveMSG (04-08-2021), soundman98 (04-07-2021)
Old 04-08-2021, 12:33 AM   #19012
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Changed the gearbox and dif oils
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
BrahmaBull1990 (04-10-2021), NoHaveMSG (04-08-2021)
