| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru brz limited
Oil pressure sender
Engine was running decent after its first start up from a rebuild but notice oil pressure dropping dramatically so stopped engine and my damn oil pressure sensor is pouring from the threads Not leaking, POURING. I then replaced the sensor and that didn’t help. I did take the sensor off when i got the timing cover cleaned i may have over tightened and damaged thread size. any solutions? I do have pressures gauges
![]() Sent from my iPhone using Tapatalk Last edited by IsaiahW; 04-03-2021 at 06:56 PM. |
#3 |
Oil pressure sender
Yup after inspecting closely it appears i have a crack i literally just got this engine rebuilt i dont think this is fixable so a couple qts of expensive breakin oil wasted
![]() Sent from my iPhone using Tapatalk |
#4 |
Well that sucks! Where is HUMFRS? I bet Buba is going to recommend som JB weld.
#5 |
Drives: Crapcan
I have a spare timing cover I was going to use for a project you can have for free, just pay shipping. PM me if you want it.
| The Following 10 Users Say Thank You to NoHaveMSG For This Useful Post: | Bonburner (04-04-2021), BrahmaBull1990 (04-10-2021), Capt Spaulding (04-04-2021), CrowsFeast (04-06-2021), HKz (04-14-2021), IsaiahW (04-04-2021), Tcoat (04-10-2021), timurrrr (04-08-2021), tintumz22 (04-05-2021), Ultramaroon (04-04-2021) |
#6 |
Nooooooo!
#7 | |
6/22/12-2/6/24
#9 |
has a funny hat
Drives: 2014 BRZ Limited
| The Following User Says Thank You to pope For This Useful Post: | Ultramaroon (04-10-2021) |
#10 |
+1 I was shocked when a buddy fixed a cracked iron block with it. Lasted at least a year. Then I moved away. Lost track.
#11 | ||
So at that point you may as well just replace it. Especially when a free one is offered up!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (04-10-2021), Ultramaroon (04-10-2021) |
#12 | |
OP either wasn't aware of, or greatly underestimated the wedging action of a tapered thread. The temp sensor was also way over-torqued. We can see that it's bottomed out. There are torque values published for these fittings but in reality, they only need to be tightened until there's a smidge of resistance. The thread sealant will do the rest. If the threads are in good shape, and are clean, might even get away with skipping the sealant. Most service-related damage comes from over-torquing or cross-threading fasteners. Even "experienced" mechanics rarely appreciate how much care it takes to reuse threaded joints without damaging them. This is especially true for steel screws in soft aluminum.
#13 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tcoat (04-10-2021) |
| DIY - Oil pressure sender and gauge (Auberins) | Trap63 | DIY (Do-It-Yourself) Guides | 15 | 09-03-2021 01:48 AM |
| Removing OEM Oil Temp/Pressure sender | Bodalenko | DIY (Do-It-Yourself) Guides | 6 | 11-30-2017 04:32 PM |
| -=-=SOLD-=-=- AEM Fuel Pressure Gauge+Sender | Ivegotamain2 | Interior Parts (Incl. Lighting) | 0 | 09-29-2016 12:38 PM |
| Oil pressure sender thread size | lbroskee | Engine, Exhaust, Transmission | 8 | 10-30-2015 12:56 AM |
| Oil Pressure Sender Unit Fitment Question | Captain Snooze | Engine, Exhaust, Transmission | 2 | 07-06-2013 01:41 AM |
