Old 03-29-2021, 01:02 PM   #18985
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
There is a picture on here somewhere of a recent engine bay fire from throwing a rod. That was already in my head after losing an engine on track.
i 110% dodged a bullet here. luckily i rolled up and off ramp so all the oil pooling on my skid plat was running off and onto the street. my ace headers are now a nice brown from the oil that did spray on it. also adding an extinguisher to my build list
Old 03-29-2021, 01:28 PM   #18986
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by Breadman View Post
i blew my engine cruising on the highway today lol fuck me
How many miles on the odometer?
Has the car been tracked often or at all?
LimitedSlip is offline   Reply With Quote
Old 03-29-2021, 01:38 PM   #18987
Breadman
Breadman's Avatar
37k and yes for the last 3 years. if the engine is anything like my tob and clutch i trashed it
Old 03-29-2021, 01:53 PM   #18988
Breadman
Breadman's Avatar
ups just showed up and i just signed for my supercharger... what timing
The Following User Says Thank You to Breadman For This Useful Post:
Dzmitry (03-29-2021)
Old 03-29-2021, 02:11 PM   #18989
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Will be a nice center piece on the dinning table till you get the car running again
Old 03-29-2021, 08:18 PM   #18990
Breadman
Breadman's Avatar
Originally Posted by BrahmaBull1990 View Post
Whoa. Can a simple header and tune cause that or just bad luck?
Time to rebuilt it AOL style; bigger, faster, stronger.
so i took most of the stuff apart and found a nice hole on the cam covers on one side. so i dropped the pan and its like sifting for gold. took off the oil pick up and found some strands of gasket maker in there.
my theory was avcs failed a retainer or cam then punched a hole and it sprayed all the oil out until the valve hit the piston and killed the engine. this makes sense because i lost power before a bang and the car hopped. also oil sprayed out of my passenger wheelwell. oh yeah they also resealed my heads because they were leaking 600 miles ago. calling the dealer and telling them they are fixing it. i have a blackstone for 800 miles ago and no wear metals
BrahmaBull1990 (03-29-2021)
Old 03-29-2021, 08:44 PM   #18991
Breadman
Breadman's Avatar
double post but heres a quick tear down. calling the dealer tomorrow since they resealed my heads less than 600 miles ago
The Following 2 Users Say Thank You to Breadman For This Useful Post:
MJones_RB (04-02-2021), tintumz22 (04-02-2021)
Old 03-29-2021, 08:46 PM   #18992
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
That’s crazy you had leaking heads with a 2017. The dealer better pay some of it (or all of it)
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-29-2021, 08:51 PM   #18993
Breadman
Breadman's Avatar
they denied the leak for 3 months saying whoever changed my oil spilled it on the pan. then i braked cleaned everything and took it back and it was covered and they said it could be a bunch of things so i tracer dyed it then they tried to say i had a tune so they werent going to cover it and i pointed out it literally had nothing to do with oil.
Old 04-02-2021, 05:21 AM   #18994
GaDgeT
GaDgeT's Avatar
Installed the Slambert Engineering Hitch and tow pack, loading, transport and life made so much easier..
GaDgeT is offline   Reply With Quote
The Following 5 Users Say Thank You to GaDgeT For This Useful Post:
beltax90 (04-03-2021), BrahmaBull1990 (04-05-2021), marky (04-08-2021), soundman98 (04-02-2021), vintagemxer (04-05-2021)
Old 04-02-2021, 07:53 AM   #18995
JD001
JD001's Avatar
Drives: Subaru BRZ
As was promised, I got the car taxed yesterday, pumped up the tyres and took it out for a drive.. this after 3 months of zero activity..
The Following 5 Users Say Thank You to JD001 For This Useful Post:
beltax90 (04-03-2021), BrahmaBull1990 (04-05-2021), Dadhawk (04-02-2021), soundman98 (04-02-2021), Ultramaroon (04-05-2021)
Old 04-05-2021, 08:40 AM   #18996
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Originally Posted by bart2ooo View Post
Is that the HKS Spec L2 Exhaust i see?
Yeah, HKS Hi-Power Spec-L
I love it, sounds great and very light for a stainless dual exit.
Breezio is offline   Reply With Quote
Old 04-05-2021, 12:12 PM   #18997
bart2ooo
Drives: 2019 BRZ Limited PP
Anything else done to the exhaust setup? I'm thinking about getting the Spec-L once i get my Tomei UEL but i'm not sure how loud it'll be as far as cold starts and neighbors lol
bart2ooo is offline   Reply With Quote
Old 04-05-2021, 10:29 PM   #18998
Breezio
Breezio's Avatar
It should be fine if you keep oem over pipe and front pipe.
I have the old OpenFlash UEL catless header, oem over pipe and front pipe. It's not too loud. My tune does have a reduced cold start idle so I can't speak for that particular portion.
Here is what she sounds like at full tilt, microphone is attached at the rear license plate.
The Following User Says Thank You to Breezio For This Useful Post:
