#15 | |
#17 |
ProCrastinationConsultant
dryer sheets also work, as does irish springs soap, btw.
#18 |
Personal bad luck with dryer sheets and Irish spring. Good luck with mothballs but the smell lasts months, so peppermint oil is my next try.
| The Following User Says Thank You to ls1ac For This Useful Post: | soundman98 (03-19-2021) |
#19 |
Drives: 2013 frs red
My car sat for 2 years. Started occasionally but had a battery tender hooked up. No problem
#20 |
Drives: Subaru BRZ
#21 |
#22 | |
Drives: 2017 BRZ PP, 2004 WRX
This is what I did for 3 months and it was probably overkill. I used Stabil in the gas tank and filled it up to prevent moisture, even though it was in an attached garage. Oil change, but didn't replace the filter (did that when I brought it out in the spring, only had 4k miles on it). Filled tires to 50PSI to prevent flat spotting. I did not use a trickle charger, but when checking the voltage after 3 months, it was low and showed about 40% charge remaining. So I put a trickle charger on it overnight and all was good. All this is probably overkill. I know people I race with that leave their cars outside with whatever fuel is left, no Stabil, no oil change, and not battery tender. Snow, ice, and sub zero temperatures for months. Worst that happens is the battery is dead and they get a new one every year. Long term, it probably isn't kind to the car however.
#23 |
Drives: 2013 Black Brz Premium 6sp
Thanks for the info. i will try it.
#24 |
Drives: Subaru BRZ
As mentioned here and elsewhere, my car sat for just over 3months! Didn't touch a thing, not even a tyre valve cap.. Installed a freshly charged battery, started her up,no issues, pumped up the tyres and off I went for a drive (this was the evening of the 1st April). Not touched her since....
#25 |
usually the carbs need adjusting after sitting so long.
| The Following User Says Thank You to soundman98 For This Useful Post: | JD001 (04-03-2021) |
#26 |
Drives: Subaru BRZ
| The Following User Says Thank You to JD001 For This Useful Post: | soundman98 (04-03-2021) |
#27 |
it started for about 3 secs and threw a code. i was hoping it would just turn and not start. o well.
| Storing the BRZ for 9 months | ShadowReaper | BRZ First-Gen (2012+) — General Topics | 25 | 01-18-2017 11:43 PM |
| Storing for a year | dragonwiddd | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-05-2014 08:12 AM |
| Storing Car For 9 Months | Touge86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 11-11-2013 10:21 AM |
| Storing my car | SmsAlSuwaidi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 06-22-2013 06:38 PM |
| Storing an unused car? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-21-2012 10:51 PM |
