Old 07-21-2012, 03:29 PM   #1
mashal
DADA
mashal's Avatar
Drives: 2013
How do I check the tranny oil?
I have never owned a car that doesn't have a dipstick for the tranny oil, so I was reading some of the posts on here on how to check it, the "fill" hole on the side of the tranny some are saying is the only way?
I don't have a way of jacking up the car completely off the ground right now and I don't think I can check tranny oil if it's on ramps .
Any suggestions on other ways of doing this ?
mashal is offline   Reply With Quote
Old 07-21-2012, 04:06 PM   #2
getbent
Drives: 2013 FR-S Blue MT
The transmission has two plugs, the higher one is the fill hole the lower is the drain hole. To check it just remove the bolt for the fill hole and stick your finger in there to see the oil level.
When doing a fluid change, you drain it from the lower drain hole then fill it from the upper fill hole until oil starts coming out.
Its basically identical to changing the fluid for the rear differential.
getbent is offline   Reply With Quote
Old 07-21-2012, 06:30 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
^ essentially true. I don't have the shop manual in front of me, so I'm not sure of the exact level... Some cars call for the fluid to be level with the bottom of the top hole, while some manufacturers like it about 1/2" below the hole. The car must be level when doing this, so ramps won't work unless you also jack up the rear to match the height.
Old 07-22-2012, 02:20 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Level with the bottom of hole but the car must be "level" to get an accurate reading. This is intended to be done on a lift but if you're doing it in the garage then put the entire car in the air with 4 jack stands.
edit: advice is regarding 6MT.
Old 07-22-2012, 05:08 PM   #5
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
With the automatic it's not quite so easy, there are three holes, two on the bottom and one on the side. One of the bottom ones is the drain hole and the other is a "Check" hole. To check the transmission fluid you have to start the car in park and then check the fluid using the check hole while the car is running. If fluid drips out slowly it's the right level, if it pours out then there was too much and replace the plug when it starts dripping, if there are no drips you need to add fluid. There may be some other steps in there, My Tacoma uses the same type of automatic transmission (albeit much larger) with the Toyota WorldSpec ATF (WS)/Subaru WS ATF fluid and the transmission fluid check is VERY complex, it requires jumping pins on the OBD port while the engine is cold, then starting the engine, shifting from park to neutral to drive a prescribed number of times which puts the transmission into "Fluid Check Mode" then you have to sit there for 15 minutes and wait while the transmission comes up to temperature, once the transmission comes to a very specific temp a light on the dash illuminates and THEN you can use the check hole to check fluid levels while the truck is in park. It's very complicated...I don't know if the BRZ requires that complex of a procedure...check the service manual it is posted in the stickies in the top of this section.
EDIT: I just checked the manual and yes he Automatic transmission has the same complex procedure as my Tacoma. Requires jumping pins on the OBD port and waiting for the proper temperature after shifting it into "Oil Temp Detection Mode." It's...a pain.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
Xanatos (03-08-2016)
Old 07-26-2012, 05:34 PM   #6
Skye
Drives: TR2,CooperS,BRZ
Drain plug
Does the brz plug have a magnetic insert? Has anyone know whether GL 3 or GL 5 is best?
Skye is offline   Reply With Quote
Old 07-26-2012, 07:50 PM   #7
roddy
roddy's Avatar
GL 3 Is the recommended fluid, but it is an old spec, and not too easy to come by. GL 5 is (typically) more of a rear diff fluid, and may contain additives that aren't good for the synchros in the trans. Some GL 5s are ok, but I wouldn't chance it. GL 4 should be ok to use. I just picked up some Redline MT-90 (75W90, GL4 synthetic) yesterday, and plan on changing the trans lube this weekend. I'm not sure yet if the drain plug is magnetic or not. I'll be pleasantly surprised if it is.
Old 07-26-2012, 07:56 PM   #8
os86
Drives: 2jz
try this
Originally Posted by tibsy92 View Post
The manual tranny has a dipstick like the subaru wrx's underneath all the cabling in an awkward position on the side, hard to find but it was found.. eventually.. its where the transmission filler plug is on the side.. . if not you'll have to either jack up your car and remove the underneath cover or try bend in from the top and remove the filler plug on the side of the transmission and insert a dipstick to check if there is any :
hope this helps
Attachment 9992
os86 is offline   Reply With Quote
Old 07-26-2012, 11:10 PM   #9
Skye
Back to roddy: what about MG gear oil special II?
Old 07-27-2012, 03:54 AM   #10
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Did your car come with an owners manuel?
chulooz is offline   Reply With Quote
Old 07-27-2012, 07:15 AM   #11
roddy
roddy's Avatar
I believe that is the recommended fluid. I remember someone posting that they went to the dealer, and they didn't have it, or could only get it by the pail. To be honest, I didn't even try. I like to run aftermarket full synthetics any time I can anyway. I'll be at the dealership today to pick up a TRD air filter. If I can remember to do so, I'll ask about the MG special II while I'm there.
Old 07-29-2012, 02:09 AM   #12
roddy
roddy's Avatar
I can confirm that both the transmission and the rear diff have magnetic drain plugs as stock. I used Redline's MT-90 GL4 manual trans lube in the transmission, and their 75W85 GL5 lightweight gear oil in the diff.
Sidenote: At 2000 miles the magnet on the rear diff drain plug was already kind of grungy... I'm not too concerned. That is pretty normal for rear gears while wearing in. The drain plug in the transmission was not bad at all.
Old 07-29-2012, 12:52 PM   #13
huma
Drives: ITR
Does anyone know if we can use a fumoto valve for the transmission drain bolt?
huma is offline   Reply With Quote
Old 07-29-2012, 01:17 PM   #14
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
How does the transmission feel/shift with the Redline MT-90 GL4?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) — General Topics 85 06-22-2012 05:22 PM
pulling e-brake with auto tranny carbonBLUE Engine, Exhaust, Transmission 2 05-16-2012 04:27 PM
How strong is tranny? theaero Engine, Exhaust, Transmission 14 04-27-2012 07:51 AM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
name that tranny! (updated: AZ6 transmission from FR-S/BRZ/GT86) carbonBLUE Engine, Exhaust, Transmission 14 12-19-2011 04:00 AM
