Old 03-15-2021, 05:38 AM   #2003
tomm.brz
Drives: brz 2017 hksv2
well same opinion as last time, it s good but could be a bit better for your car
Old 03-15-2021, 02:20 PM   #2004
LancePower
Drives: 2020 BRZ tS
Nothing dangerous? Just not optimized?
Was the v159 any better?
https://datazap.me/u/lancepower/wayn...7-8-9-10-11-14
LancePower is online now   Reply With Quote
Old 03-15-2021, 08:01 PM   #2005
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Looks fine. 159 and 160 have the exact same timing and maf btw.
The Following User Says Thank You to Wayno For This Useful Post:
LancePower (03-16-2021)
Old 03-16-2021, 04:11 AM   #2006
LancePower
Drives: 2020 BRZ tS
Which looks better for my car?
Old 03-16-2021, 08:12 AM   #2007
tomm.brz
trust Wayne and use his latest version, his OTS tunes are always good
i was just referring that being an OTS tune, there is always some margin of improvements in maf and timing
Still you can drive it without worrying and logs look both good enough
Old 03-21-2021, 07:41 PM   #2008
73TORANA!
Drives: Orange GTS
Hi All still getting my head around all this, I leaned out the MAF from 3.4 to 5 volts and pulled some timing up top 1 deg from 6.8k to 7.6k rpm. AFR changed by 0.1 from previous pull but still getting FLKC not game to lean out any more as I recon im about to dig a hole. I did lean it out for a test to get around 11.7 WOT 4k to 7k rpm, car pulled hard but IAM dropped and heaps of FLKC so went back to the settings on this pull. Any advice pse. Waynes Stg2 UEL 89.98 E0 Default v163 A01I. I had to use the OFT stg 2 MAF scale as I was getting + 5 to +7 LTFT's with Wayne MAF scale now LTFT trims are consistently around +- 1.56%.Cheers.
https://datazap.me/u/vk3xhm/stg2-uel...data=1-8-10-12
73TORANA! is offline   Reply With Quote
Old 03-22-2021, 03:23 AM   #2009
tomm.brz
correct more when ecu corrects and could be ok
Old 03-24-2021, 11:54 PM   #2010
kev0
Drives: '14
https://datazap.me/u/kev0/short-pull?log=0&data=18
Hi, can I get an opinion on this log? I was getting false knock before due to a loose battery tie down. Basically, one nut was missing so the bracket and my battery was flopping around a bit and I think it was setting my knock sensor off, causing my advance multiplier to drop to low .40's at times. I think it's fixed now but let me know what you think
kev0 is offline   Reply With Quote
Old 03-25-2021, 01:57 AM   #2011
tomm.brz
a bit rich-scaled but all ok
kev0 (03-25-2021)
Old 03-25-2021, 02:40 AM   #2012
73TORANA!
Drives: Orange GTS
Can you do a 3rd gear pull to 7krpm. how many km's have you done since flash? Are you using Waynes roms or have you done your own?
Old 03-25-2021, 05:29 AM   #2013
tomm.brz
that s an ecutek FI custom (either from him or a tuner) tune..
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
73TORANA! (03-25-2021), kev0 (03-25-2021)
Old 04-08-2021, 01:39 PM   #2014
petermmdk
Drives: 2017 BRZ blue
Hi Specialists
My 2017 BRZ black manifold is running Wayne v164. (K00G, 100 oktan) flashed with OpenFlashTablet.
Only modification to the car is Tuning Developments manifold.
The AFR are a little low
6000 RPM - AFR 11.71
6500 RPM - AFR 11.60 to 11.37
6800 RPM - AFR 11.37
Target is 11.7 til 11.9
I am a real amateur so not in any way able to understand other data from the log. Are the data OK or should I get someone to make me a remote tune? And who?
I will be tracking the car soon so want to be sure not to damage anything!
https://datazap.me/u/petermmdk/log-1...log=0&data=1-9
Thanks in advance;-)
petermmdk is offline   Reply With Quote
Old 04-08-2021, 05:13 PM   #2015
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Originally Posted by petermmdk View Post
Hi Specialists
It`s a bit rich The LTFT is looking for more fuel. You have some knock more at 6.3k and the ecu is pulling timing.
I`m not an expert either, but that tune is not good for tracking IMO. Maybe a maf re scale will fix it or the lesser octane/fuel tune.
Some one will come along that can help.
Old 04-08-2021, 05:29 PM   #2016
petermmdk
Thanks gen3v8
I have been contacted my an expert who will modify the tune for me.
Glad I asked before going to the track.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
