#2003 |
Drives: brz 2017 hksv2
well same opinion as last time, it s good but could be a bit better for your car
#2004 | |
Drives: 2020 BRZ tS
Nothing dangerous? Just not optimized? Was the v159 any better? https://datazap.me/u/lancepower/wayn...7-8-9-10-11-14 |
#2005 | |
Drives: Toyota 86 GTS
#2006 |
Drives: 2020 BRZ tS
#2007 |
trust Wayne and use his latest version, his OTS tunes are always good
i was just referring that being an OTS tune, there is always some margin of improvements in maf and timing Still you can drive it without worrying and logs look both good enough |
#2008 |
Drives: Orange GTS
Hi All still getting my head around all this, I leaned out the MAF from 3.4 to 5 volts and pulled some timing up top 1 deg from 6.8k to 7.6k rpm. AFR changed by 0.1 from previous pull but still getting FLKC not game to lean out any more as I recon im about to dig a hole. I did lean it out for a test to get around 11.7 WOT 4k to 7k rpm, car pulled hard but IAM dropped and heaps of FLKC so went back to the settings on this pull. Any advice pse. Waynes Stg2 UEL 89.98 E0 Default v163 A01I. I had to use the OFT stg 2 MAF scale as I was getting + 5 to +7 LTFT's with Wayne MAF scale now LTFT trims are consistently around +- 1.56%.Cheers.
https://datazap.me/u/vk3xhm/stg2-uel...data=1-8-10-12 Last edited by 73TORANA!; 03-22-2021 at 06:35 PM. |
#2009 |
correct more when ecu corrects and could be ok
#2010 |
Drives: '14
https://datazap.me/u/kev0/short-pull?log=0&data=18
Hi, can I get an opinion on this log? I was getting false knock before due to a loose battery tie down. Basically, one nut was missing so the bracket and my battery was flopping around a bit and I think it was setting my knock sensor off, causing my advance multiplier to drop to low .40's at times. I think it's fixed now but let me know what you think |
#2011 |
a bit rich-scaled but all ok
#2012 | |
Drives: Orange GTS
#2013 |
#2014 |
Drives: 2017 BRZ blue
Hi Specialists
My 2017 BRZ black manifold is running Wayne v164. (K00G, 100 oktan) flashed with OpenFlashTablet. Only modification to the car is Tuning Developments manifold. The AFR are a little low 6000 RPM - AFR 11.71 6500 RPM - AFR 11.60 to 11.37 6800 RPM - AFR 11.37 Target is 11.7 til 11.9 I am a real amateur so not in any way able to understand other data from the log. Are the data OK or should I get someone to make me a remote tune? And who? I will be tracking the car soon so want to be sure not to damage anything! https://datazap.me/u/petermmdk/log-1...log=0&data=1-9 Thanks in advance;-) |
#2015 | |
30 minute maintenance
Drives: My18 wrxsti
I`m not an expert either, but that tune is not good for tracking IMO. Maybe a maf re scale will fix it or the lesser octane/fuel tune. Some one will come along that can help. |
#2016 |
Thanks gen3v8
I have been contacted my an expert who will modify the tune for me. Glad I asked before going to the track. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
