Drives: 2014 Firestorm FRS
Strange Loud Noise
Hello! I've been hearing a strange loud noise the past few months, to the best of my knowledge it is coming from the front.
The sound is not reproducible on demand. So I could not jump in and go make the noise happen. I have tried many times. It usually happens after about 13 miles (half freeway half streets), around the same exact area. That area involves a slight left turn into a left turn lane, then the normal left turn, and then a light right curve before turning into an uphill straight. It doesn't happen every time and it doesn't matter if I am turning or going straight. It does only happen at speeds of about 5-20 MPH. It seems to start when I let off the gas after the slight left, but it will continue with the gas pedal pressed. Other times it would start after I make the left turn, or during. The noise does not happen often, maybe once a week or once every other week. In mid February I heard it faintly as I let off the gas and approached the left turn so I started recording and got a good video. Toward the end is when you hear it the best. Since that video the noise rarely happened again, maybe once every other week, if at all. I haven't taken it anywhere to get looked at as it drives perfectly normal and I can't reproduce the noise. It'll only happen sometimes in that area. Coming home today it happened again just like in the video, really loud, except I noticed the steering wheel vibrating a bit more than usual during the noise. I had not noticed that the previous times it happened, so maybe it was not related. This time it happened for 1 second during the left turn, then 30 seconds after that little blurp it started again a good way up the hill, going straight. It lasted for 7 seconds. I pulled the dashcam video which is how I figured that. Couldn't reproduce it again once it was gone. It sounded the same as the video I posted. Has anybody heard a noise like this before? Any idea what it could be? I've been trying to figure it out for a while and I can't find anything that sounds like it online in any videos. This started happening in January (I think) and it has happened probably 7-10 times since then. My car is a 2014 FRS, only mods are stage 1 OFT 91 gas, RSR Super Down springs (about 1.5 inch drop), 18in Rota Grids, TRD exhaust and TRD intake. I've had this FRS for just over 6 years and it has about 60K miles on it. I've only done the regular oil changes and other minor things, nothing major. The car hasn't been in any accidents or had any parts replaced (other than springs and wheels/tires). Thank you for taking the time to help out! Last edited by Nictheguy; 03-24-2021 at 09:01 PM. |
| The Following User Says Thank You to Nictheguy For This Useful Post: | humfrz (03-25-2021) |
#2 |
Wheel bearing
Sent from my SM-G975U using Tapatalk |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
It could be a few things, wheel bearings as mentioned.
Another ideas I can come up with is bad ball joints, top hats on the front struts are loose making the springs move a tad. Sway bars bushings Heck, long shot but could be the throw out bearing?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | Nictheguy (03-25-2021) |
#4 | |
I would suggest that you take your car to a good alignment shop, explain what is going on and ask them to inspect the front end suspension parts while they are checking the alignment.
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Nictheguy (03-25-2021), soundman98 (03-26-2021) |
| Strange noise from handbrake | Zeezy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 04-07-2016 07:21 AM |
| Strange noise | Tiliziano | Issues | Warranty | Recalls / TSB | 1 | 06-05-2015 04:20 PM |
| Strange Noise from rear of car while OFF | mike2100 | Issues | Warranty | Recalls / TSB | 23 | 12-17-2014 08:14 PM |
| New strange noise? | kALMIGHTY | Issues | Warranty | Recalls / TSB | 45 | 05-02-2014 01:52 AM |
| Strange noise | Random_Art | Other Vehicles & General Automotive Discussions | 15 | 06-03-2011 03:31 PM |
