| Software Tuning Discuss all software tuning topics. |
#15 | |
#16 |
Drives: brz 2017 hksv2
No.
Actually cold start is leanish in this car, warm start too a little And it's actually in open loop state when you first start it cold If you measure AFR with a wideband with a stock tune, you ll see subaru afr stuck around 14.7/15.16 (it has various level undefined to me) Meanwhile the wideband measures even slightly leaner The pops are from stratified and retarded DI injection and negative ignition timing, combined with the timing retard induced by the throttle blipping, both pushing it and releasing it There are also other OEM tables that limit the amount of retard while coolant is cold and while clutch is pressed (ever noticed sound changes when you press clutch to go in reverse during cold start?) and while it's complicated to see how and when those tables act, the burbles you get are mostly from retarded ignition timings |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | Dzmitry (03-22-2021), Ultramaroon (03-20-2021) |
#17 |
Just no!
#18 |
Sorry I wasn't clear on what part of his comment I was addressing.
Yes all you said is accurate and when you add sudden fuel to those conditions you get more pops than normal.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (03-20-2021) |
#19 | |
Drives: FT86
During high idle cold start ecu also retards timing stock its -15 |
| The Following User Says Thank You to steve99 For This Useful Post: | Ultramaroon (03-20-2021) |
#20 |
ProCrastinationConsultant
it could be, but it's not the problem here.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#21 |
#22 |
This thread is retarded -15
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | JD001 (03-20-2021), NoHaveMSG (03-20-2021), saltywetman (03-22-2021), soundman98 (03-19-2021), tomm.brz (03-19-2021) |
| Crackle pops during wot | Dr. BRZ | Engine, Exhaust, Transmission | 40 | 03-19-2020 03:02 PM |
| OFT POPS | gt7877 | Software Tuning | 3 | 11-24-2019 05:09 PM |
| Exhaust pops & bangs | James H | BRZ First-Gen (2012+) — General Topics | 43 | 09-14-2019 04:45 AM |
| Sport Mode pops | gt7877 | Software Tuning | 3 | 11-20-2018 05:37 AM |
| OFT Backfire/Pops help | DaveyBonesJones | Southern California | 8 | 08-27-2018 12:53 PM |
