Old 03-19-2021, 11:40 AM   #15
Originally Posted by Varelco View Post
Mine does it on the stock map under the right conditions. On high idle sometimes if I blip the throttle it pops and burbles nicely, doesn't when its warm or during the 'pulse jet/sonic boom part of a cold start. Anyone know what the ECU does in a high idle as to why it might do this?
Pours more fuel in.
Old 03-19-2021, 02:31 PM   #16
tomm.brz
Drives: brz 2017 hksv2
Pours more fuel in.
No.
Actually cold start is leanish in this car, warm start too a little
And it's actually in open loop state when you first start it cold
If you measure AFR with a wideband with a stock tune, you ll see subaru afr stuck around 14.7/15.16 (it has various level undefined to me)
Meanwhile the wideband measures even slightly leaner
The pops are from stratified and retarded DI injection and negative ignition timing, combined with the timing retard induced by the throttle blipping, both pushing it and releasing it
There are also other OEM tables that limit the amount of retard while coolant is cold and while clutch is pressed (ever noticed sound changes when you press clutch to go in reverse during cold start?) and while it's complicated to see how and when those tables act, the burbles you get are mostly from retarded ignition timings
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Dzmitry (03-22-2021), Ultramaroon (03-20-2021)
Old 03-19-2021, 03:06 PM   #17
Ernest72
Just no!
Old 03-19-2021, 04:13 PM   #18
Pours more fuel in.
Originally Posted by tomm.brz View Post
No.
Sorry I wasn't clear on what part of his comment I was addressing.
Yes all you said is accurate and when you add sudden fuel to those conditions you get more pops than normal.
Old 03-19-2021, 05:40 PM   #19
steve99
Drives: FT86
During high idle cold start ecu also retards timing stock its -15
Ultramaroon (03-19-2021)
Old 03-19-2021, 07:48 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
I am hoping that the audio on my phone is shite.
it could be, but it's not the problem here.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
JD001 (03-20-2021), NoHaveMSG (03-20-2021), Ultramaroon (03-19-2021)
Old 03-19-2021, 08:18 PM   #21
lol
Old 03-19-2021, 08:21 PM   #22
This thread is retarded -15
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
JD001 (03-20-2021), NoHaveMSG (03-20-2021), saltywetman (03-22-2021), soundman98 (03-19-2021), tomm.brz (03-19-2021)
Crackle pops during wot Dr. BRZ Engine, Exhaust, Transmission 40 03-19-2020 02:02 PM
OFT POPS gt7877 Software Tuning 3 11-24-2019 04:09 PM
Exhaust pops & bangs James H BRZ First-Gen (2012+) — General Topics 43 09-14-2019 03:45 AM
Sport Mode pops gt7877 Software Tuning 3 11-20-2018 04:37 AM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
