| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 | ||
Howdy
Drives: 2020 BRZ PP
@9 minutes. They dyno'd stock and with headers+tune. Ignore the click-bait title, but they did make good gains. Maybe we have a middle ground?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#58 |
Drives: 17 Asphalt 86
15-20whp gain is seems doable with a good tune and a catless header. For peak numbers to matter you need a baseline to compare it too. Some cars baseline as low as 145-150whp on certain dynos, others as high as 170whp.
All that matters is the spread to me. A high reading dyno looks good on paper when you show it to someone. |
#59 | |
The difference probably would have been even larger if it was bone stock. |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | BrahmaBull1990 (03-18-2021), Dzmitry (03-18-2021) |
#60 | |
Drives: 2018 Subaru BRZ Limited with PP
EDIT: Got myself mixed up, the header already on could side with getting even more gains over stock. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | BrahmaBull1990 (03-18-2021) |
#61 |
Howdy
Drives: 2020 BRZ PP
I mis-spoke. Another video had their stock dyno-run, but at the end they have a chart up of a stock dyno-run for comparison (just not this exact car).
#62 | |
Howdy
Drives: 2020 BRZ PP
#63 | |
Why is that? Simple, because of exactly how this conversation began, the engine is already near its peak. There is only so much you can do to it. |
#64 | |
#65 | |
Howdy
Drives: 2020 BRZ PP
| The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | Dzmitry (03-18-2021) |
#66 | |
The factory tune and the updated factory header are the big changes on 17+ cars. It has larger runners compared to the older design, similar to aftermarket headers. But it still retains the same huge restrictive cat. There is a thread buried somewhere indicating the differences. Once aftermarket parts are thrown on I don't think anyone has been able to provide a measurable difference between the revised engine and the old one. There is a build thread with custom tuning done on a stock decatted 17+ header and front pipe which showed comparable gains to most aftermarket catless setups. |
#67 | |
The dyno is on the first page a bit down. |
| The Following 2 Users Say Thank You to Dzmitry For This Useful Post: | BrahmaBull1990 (03-18-2021), RToyo86 (03-18-2021) |
#68 | |
30 minute maintenance
Drives: My18 wrxsti
Pulse Racing have a Happy Dyno. They boast big numbers and do good work and their dyno like all dynos is a tuning tool. I had one of my cars(turbo) done by them it came back @ 212Wkw. I went to a dyno day and it made 187wkw which was good on the day compared to others of similar mods. Baseline on the day was 130+-140+ wkw stock. |
| The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | BrahmaBull1990 (03-18-2021), Dzmitry (03-19-2021) |
#69 | |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
FT86 Speed Factory UEL, catted Crawford Billet Power Block (BPB)/Intake Manifold Spacer OFT w/ Crawford BPB Tune To further reduce my environmental impact, I take the electric to work & only used the car on weekends or short trips to Costco.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
| Tags |
| torque, torque solution, tune |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
| Torque Pro | sav | AFRICA | 33 | 08-27-2013 07:31 AM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
