Old 03-11-2021, 09:57 AM   #1
BitusB
BitusB's Avatar
Drives: 2020 BRZ rs
Eliminating torque dip
Is it necessary to swap out stock header to address torque dip or can a tune alone do the trick? I prefer to have a cat for sound and environmental reasons.
BitusB is offline   Reply With Quote
The Following User Says Thank You to BitusB For This Useful Post:
jcw99 (03-16-2021)
Old 03-11-2021, 10:08 AM   #2
mrhemi
A supercharger takes care of that.
mrhemi is offline   Reply With Quote
The Following User Says Thank You to mrhemi For This Useful Post:
p1l0t (03-11-2021)
Old 03-11-2021, 10:20 AM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
The headers do help decrease most of the torque dip. A tune can also help, but preferably with the help of a new header. Or like the comment above, boosting resolves that too. It all depends on what application you plan on sticking with (NA/Boost). If you add a turbo, you'll have to change the headers anyways. You can get for example, a JDL UEL/EL and be able to add a SC without replacing the headers.
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
BitusB (03-11-2021), p1l0t (03-11-2021)
Old 03-11-2021, 10:20 AM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
A tune will help, but not too much.
https://www.ft86club.com/forums/showthread.php?t=121315
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
Old 03-11-2021, 10:31 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
E85 tune will do it if you have E85 available.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
BitusB (03-11-2021), Dzmitry (03-11-2021), Lantanafrs2 (03-11-2021), p1l0t (03-11-2021), spike021 (03-11-2021)
Old 03-11-2021, 11:13 AM   #6
Ohio Enthusiast
Drives: 2018 BRZ
My understanding is that removing the cats (either with an aftermarket header or by decating the OEM one) is what allows the tune to improve the torque dip. On top of that, the 2017+ engine changes make the tune+header less noticeable vs. the pre-2017 models.
Ohio Enthusiast is offline   Reply With Quote
Old 03-11-2021, 12:01 PM   #7
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Catless header and tune. Like 80% gone and for sure noticeable driving round town
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-11-2021, 12:21 PM   #8
alphasaur
friendly
Drives: 17' 86
I run a catted header (ft86 speed factory) with a tune from Mike @Xero-Limit and I don't seem to have the dip anymore.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 03-11-2021, 12:37 PM   #9
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I believe the simplest answer, already addressed by folks here is this.
A tune alone will improve power all around a bit, but will still give you the torque dip feeling, just improved.
A header and tune gives the feeling of a smooth torque curve, AKA dip eliminated.
Dzmitry is offline   Reply With Quote
Old 03-11-2021, 04:17 PM   #10
PenGun
Drives: Red 2019 Subaru BRZ
You can easily eliminate the torque dip, by staying above it. When you drive the car seriously you will never see that dip.
I dunno, kids these days.
PenGun is offline   Reply With Quote
The Following 3 Users Say Thank You to PenGun For This Useful Post:
dodj (03-30-2021), Ernest72 (03-14-2021), soundman98 (03-11-2021)
Old 03-11-2021, 05:45 PM   #11
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Agreed. Other than the first gear dip, you can keep the revs up high and never get back into that dip. Downshift when needed and when you should, and you won't have to worry about it.
That dip is there to remind you that these engines are a balance between decent performance and good fuel efficiency.
Perhaps the OP should consider an automatic only 2.0 liter Supra instead of a twin.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-11-2021, 06:00 PM   #12
Lantanafrs2
Drives: 2013 frs red
Thx for explaining the reason for the torque dip. I never knew it was meant to remind me of something
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
MuseChaser (03-12-2021)
Old 03-11-2021, 06:05 PM   #13
Lantanafrs2
Some headers will put a torque hump where the dip was. I personally prefer to drive above 4500 rpm and replace the short block every year. I also masturbate with a shoe rasp in my ass and wear my shoes on the wrong feet.
alphasaur (03-11-2021)
Old 03-11-2021, 06:08 PM   #14
alphasaur
friendly
Drives: 17' 86
You're right, wanting to be able to keep up with traffic without having to wring out the engine is for mouth breathers.
torque, torque solution, tune
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 04:09 AM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
