| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
Master Collaborator
Counterfeit Toyota Parts
There was a recent discussion here on another thread about one of our members having a problem with his O2 sensor and someone stated that he should buy a cheap replacement from RockAuto and I mentioned not to go the cheap route, but to buy the part from a local dealer due to the possibilities of counterfeit parts.
I stumbled upon this video today which proves the point I was trying to make. |
| The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post: |
#2 |
Drives: '13 FRS - STX
I had an accessory belt I bought online shred on the test drive after installing it, lasted less then 10 minutes. May have messed something up, may not, swapped back to the original I had tossed in the back seat, paid the extra $15 and bought another one from a dealership, over a year later no issues.
![]() Fun fact, local Subaru dealership wouldn't sell me a belt without a VIN. |
| The Following User Says Thank You to strat61caster For This Useful Post: | soundman98 (03-11-2021) |
#3 |
Because compromise ®
Drives: Red Herring
Yeah, I get the impression that's the way things are going. Even when buying an oil filter for mum's Yaris I'm asked for the VIN at the non-genuine aftermarket parts shop.
#4 |
I just Drive.
Drives: in the womb still
same thing with "honda" timing belt kits on Ebay....seen first hand a belt snap after like..very low miles. Heard NSX guys were snapping belts. Stay away!
Same goes for "RDX" injectors etc.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#5 |
Isn't that pretty much easy to come by though? I mean, walk through the dealership and give them their own VIN from a car in the lot.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | soundman98 (03-11-2021) |
#6 |
You presume they had a BRZ on the lot...
#7 |
Well true, but it's not like you can't come up with one, I guess that was my point. Heck you can basically look it up online and get pretty much all but the last 5 digits.
#8 | ||
There are two main reasons they ask for VINs now. The first makes sense for a lot of models even if it doesn't for the Twins. There can be many variations on the same car so by entering the VIN they can get the right part the first time. The second is related to the first in that it is a huge time saver for them. If you just go in and say year, make and model they now have to play 20 questions to dial down the options to the right part. This isn't a big deal with the Twins since there is not a pile of different versions. Nor would it be an issue with most Forum people since they could answer all the questions quickly and accurately. It would be a problem for many people when they get through the make model and year and then the only thing they know is what colour it is. So ultimately they are not asking for VINS for a confirmation that you own the car or some weird conspiracy theory that they are tracking your purchases but simply because most people are automotivly challenged and they don't want to spend half an hour trying to get the right part number for a belt.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | bcj (03-11-2021), Dadhawk (03-11-2021), soundman98 (03-11-2021), Spuds (03-11-2021), strat61caster (03-11-2021), Ultramaroon (03-11-2021) |
#9 |
At work we run into counterfeit parts at least a couple of times a year. We receive all the rotors that are replaced under warranty for evaluation. Since we make them for pickups we see a couple of pairs of ours a year. These are almost damaged by extreme overheating (loaded truck pulling a trailer down a steep hill is almost always included in the failure description) and we may see one set every couple of years with a legit manufacturing issue. Since we end of line gauge and inspect every single part that goes out the door this limited warranty work is what would be expected.
We also see three or four sets of cheap knock offs come in every year. The difference is immediately visible even though some try to copy the OEM ones right down to the pattern of the date code. The problems with them are far more numerus with noise, cracking and even complete separation of the hat and brake plates being rater common. These products are just cheap offshore ones that people put on themselves and when they fail they take it into the dealer and complain! Those cheap parts that show up are cheap for a reason but some people will never learn that lesson.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#10 | |
Master Collaborator
Yeah, I just ordered OEM front rotors for my Solara from my local Toyota dealer for $100 each and the gal at the parts counter affirmed there are counterfeit brake parts out there. I've been dealing with brake issues for years on this car and I believe it's because the mechanics that I have hired in the past have been using any old aftermarket rotor off the shelf that they just happen to have available at the time. These aftermarket rotors simply are not made to Toyota standards using high-quality alloys. They do not hold up over time and warp when they get hot causing steering wheel shimmy and the related wear and tear that it brings. If I were to order the OEM rotors from one of the online chain retailers at half the price, I would be more likely to receive counterfeit parts. It's just not worth it to me to have to put up with the problems that this would cause. |
#11 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (03-11-2021) |
#12 | ||
Parts are made to a sepc. If those specs are ignored then the product is usually crap. We can make you a $30 part or we can make the same thing for $5 just by ignoring the specs. This goes down all the way through the supply chain right to the raw materials and if at any stage the specs are ignored then the end product will suffer even if it it made the same further up the line.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (03-11-2021), Ohio Enthusiast (03-11-2021), soundman98 (03-11-2021), Ultramaroon (03-11-2021) |
#13 | |
Drives: 2018 BRZ
This leads to interesting statistical variations where brand name parts are universally good and off-brands are universally bad (as the good stuff was skimmed off and sold brand name). So if you ever wonder what's the tangible benefit of buying the better, more expensive stuff (or higher end models in a lineup), this is a fairly common industry practice. |
| The Following 5 Users Say Thank You to Ohio Enthusiast For This Useful Post: | NoHaveMSG (03-12-2021), soundman98 (03-11-2021), strat61caster (03-12-2021), Tcoat (03-11-2021), Ultramaroon (03-11-2021) |
#14 | |
Master Collaborator
How does this explain Beats headphones? |
| Toyota 86 Competition GR Parts - 4th gear + transmission parts | mav1178 | Engine, Exhaust, Transmission | 16 | 12-08-2020 08:24 PM |
| Original TRD Parts for Toyota 86 | Saaj23 | AFRICA | 12 | 09-15-2016 08:43 AM |
| Which parts are Toyota, and which parts are Subaru? | Itzed | BRZ First-Gen (2012+) — General Topics | 29 | 11-10-2014 10:57 PM |
