Old 03-06-2021, 06:04 AM   #1
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Coilover Loose/Play
Hey so I've been dialing and experimenting with different ride heights over the past few weeks and decided I was gonna almost drop the rear to max. Did the right side rear to about 1.2 cm left and went to do the left side. It was originally on 2.4 cm and while lowering as soon as it got to 1.4cmish it started to become loose and have some play (the lower you go it gets looser), so for now I put it to 1.5 cm (still a tiny bit loose) and just put the wheel back on and lowered the car.
Here's a short clip of what I mean:
Any ideas of what might be causing this? My first thought it maybe the top locking nut isn't tight enough but not entirely sure. I had a shop put the top nut cause I didn't have the right socket.
They are Tein Street Advance Z
Forgot to add, is there any harm in it having play or being loose? I would think it wouldn't matter much because the weight of the car would keep it stiff, but it's just odd it's happening to only one side.
Hamza is offline   Reply With Quote
Old 03-07-2021, 02:04 PM   #2
ninjan00dles
Drives: 2015 FRS
You can adjust preload on that corner so it isn’t loose when unloaded. Shouldn’t make any difference except reduce rattle
ninjan00dles is offline   Reply With Quote
Old 03-07-2021, 02:28 PM   #3
Hamza
Hamza's Avatar
These don't have adjustable pre-load. It's just the 2 perches to adjust height
Old 03-07-2021, 06:32 PM   #4
Grady
Grady's Avatar
Preload and ride night are one in the same. Preload is when suspension is unloaded. Ride height is when loaded. Same adjustment nut just measured different. You are over adjusted. Put some preload back in. If you want to go lower you will need different springs.
Old 03-07-2021, 07:07 PM   #5
DougKelly20
Drives: Legacy 3.6R
Not true. Pre-load is how much compression is on the spring before the suspension is loaded, ride height is how elongated the overall strut is. MOST coilovers have separate adjustments and if you don't know what you're doing you should not touch the pre-load.
DougKelly20 is offline   Reply With Quote
Old 03-07-2021, 07:57 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
I'd word it differently. If one doesn't know what one's doing, better follow manual. Some coilovers may ship in state and their installation instructions may need setting first specific preload during installation. Not touching is not exactly best option in such case.
Old 03-08-2021, 02:42 AM   #7
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Best coilover advice ever. Two things happened to me after doing this coilover rookie mistake myself: 1. Top hat camber bolts got loose and I got variable camber tophats 2. Preload adjusting collar somehow got loose and my passanger side started to make horrible clunking noise when hitting bigger bumps.
MrSkubi is online now   Reply With Quote
The Following User Says Thank You to MrSkubi For This Useful Post:
Hamza (03-08-2021)
Old 03-08-2021, 04:34 AM   #8
Hamza
Hamza's Avatar
But again these don't have adjustable pre-load and I went lower on the other side with no play in the coil that's why im confused
Old 03-08-2021, 04:35 AM   #9
Hamza
Hamza's Avatar
What do you mean by 'overadjusted'? Also the other side is lower with no play in the coil, I was just trying to match this side as that but this one started moving a bit before I even got to the same height.
Old 03-08-2021, 08:06 AM   #10
DougKelly20
Drives: Legacy 3.6R
If you mean that the spring is floating between the perches when unloaded this might be OK. I had lowering springs on my legacy where all 4 floated, granted not ideal... but I used them for a year before I switched to coils and they were "fine." (I was oversprung, but that had nothing to do with the float)
As for why you are lopsided my guess is a manufacturer defect. Did you buy them new? I'd call Tein.
Old 03-08-2021, 08:26 AM   #11
Racecomp Engineering
Lots going on here.
1. Left and right differences are normal. Most cars do not weigh exactly the same for each side.
2. Your coilovers do have preload adjustment. The adjustable perch that the spring sits on adjusts preload. Preload also affects ride height.
3. You should pay attention to both preload and shock length when adjusting ride height. Preload for 1 set up may not work for every set up.
4. Many people and even many manufacturers simply do not understand spring preload. It's one of the most common coilover questions and it frequently gets many of the same wrong answers.
Read this:
https://www.instagram.com/p/B9J1M8Un..._web_copy_link
^That won't give you all the answers, but it will give an overview.
I would recommend at least following Tein's recommendations for preload.
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Grady (03-08-2021), Hamza (03-09-2021), Tcoat (03-08-2021), vintagemxer (03-18-2021)
Old 03-08-2021, 12:56 PM   #12
Grady
Grady's Avatar
Yes but preload will affect right height. Preload and ride hight window is designed into the spring.
Old 03-08-2021, 01:02 PM   #13
Grady
Grady's Avatar
Racecomp nailed it.
Remember just because it said it is adjustable does not allow you to get any ride hight. The strut/springs were designed for a window of adjustment, sounds like you are trying to go lower then they were designed for.
Old 03-09-2021, 01:44 AM   #14
Hamza
Hamza's Avatar
Lots going on here.
Read this:
Racecomp nailed it.
The recommended adjustment for these coils from Tein was about the same as stock ride height, but the from the instructions manual the range went to a 3" drop. Right now I've only dropped 0.86" (this was coincidental lol) from stock ride height (taking it as 372mm from hub to fender and it's starting to have play.
The fronts said a 2.6" drop and I've bottomed the front out all the way and it's still way higher than 2.6", but regardless the fronts are still stiff.
My best guess now is still that the top locking nut on the strut isn't tight enough, kinda odd to tell because it's supposed to be hand tightened, and doing so every time I get scared of accidentally turning the dampening adjustment knob and breaking it (did that on the front). Can I tighten it with the strut still on the car with the car jacked up?
Loose axle bmacfrs Engine, Exhaust, Transmission 0 06-05-2020 07:56 PM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Coilover Preload collars keeps coming loose BDotG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-21-2015 10:23 PM
Loose A-pillar ryoma Cosmetic Modification (Interior/Exterior/Lighting) 2 07-15-2015 05:00 PM
Loose Glove Box Spd229 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2012 01:53 PM
