Old 03-05-2021, 06:15 PM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Here is my photoshop using a weak photoshop-like tool, but I elongated the hood and smoothed out some lines.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
WolfpackS2k (03-08-2021), ZDan (03-05-2021)
Old 03-05-2021, 06:33 PM   #30
ZDan
ZDan's Avatar
Drives: '23 BRZ
You're a lot better at this than I am, that's for sure!
For *me*, I'd rather have the shorter wheelbase than the longer hood. However, if a 500hp powerplant is going in, this ^^^ is the way to go...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Irace86.2.0 (03-07-2021), soundman98 (03-05-2021)
Old 03-05-2021, 06:41 PM   #31
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
start saving up for a f-type?
HKz is offline   Reply With Quote
Old 03-05-2021, 06:53 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
F-type looks GREAT! Love it! If they made a ~3000 lb. rwd version I'd be very interested.
Irace86.2.0 (03-05-2021)
Old 03-05-2021, 08:05 PM   #33
Irace86.2.0
I’m more a fan of the looks more than the reliability and interior. Weight and no manual at all anymore and no manual on the V8. This ties into what I was saying in the other thread about the manual transmissions going:
https://carbuzz.com/news/now-is-the-...-jaguar-f-type
Old 03-07-2021, 08:06 AM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by bfrank1972 View Post
All 100% true - I think, however, the moderate front weight bias also contributes to the overall excellent and approachable handling characteristics of 86. Not optimized for ideal performance under braking or putting power down, but you can really explore the limits of these cars without a sphincter workout.
Originally Posted by WolfpackS2k View Post
My Cayman felt considerably more twitchy than my S2000 (to me at least).
But that's not a straight F/R weight distribution comparison. The Cayman has a very low polar moment of inertia since the mass is centralized.
Thinking about this a bit more, and "twitchiness" vs. "responsiveness"...
For sure if you just move the rear wheels forward 10" with no other changes, the car will be more responsive and less understeery. Shorter wheelbase, lower polar moment, more turn rate for given steering angle, front tires less overloaded. I don't think that would make the car unstable, but for sure it would make it more *responsive*, which could be perceived as twitchiness. This could be mitigated with a slower steering rack to give same rate of turn per steering wheel input. The AP1 S2000 has plenty quick steering with a 13.9:1 rack, vs. FT86 13:1. If you ratio by wheelbase they should have the same turn rate per steering wheel input.
Leaving spring rates and sway bar rates the same (front-stiffness biased for 55/45) for the 50/50 2-seater would "correct" to some degree the change in under/oversteer balance at the limit from the improved weight distribution.
Could also go with some tire stagger. Keeping the same average 215 tire width they could go with AP1 stagger at 205F/225R. IMO not necessary but it's another knob to tweak if desired.
Anyway, I've never found *responsiveness* to be an issue with lightweight/low-polar-moment cars as long as the suspension geometry is good (AP1 shortcoming). The best-handling car I've ever driven was a tiny 600-lb. Formula 440 at Road Atlanta years ago. I had only a few track events in my 240Z under my belt at the time, and I found the F440 to be *sweet* to drive. Very pointable, but also very easy to recover.
Starting to think maybe I buy a 2nd-gen in a couple of years and do some cutting and welding on the '17 PP...
Old 03-07-2021, 12:09 PM   #35
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Also if it cost half as much and was made in Japan...
I love those 'chops, btw. I don't mind the 2+2, but I would adore a true 2-seater. Especially if it had a fastback and a liftgate like my dad's old Mustang... We can dream, right?
Cephas is offline   Reply With Quote
The Following User Says Thank You to Cephas For This Useful Post:
ZDan (03-07-2021)
Old 03-07-2021, 01:02 PM   #36
sato
sato's Avatar
Drives: Dodge Patitas
I say it looks cute AF. Don't have much use for the rear seats other than cargo room, so I guess Z-car interior proportions would be fine by me.
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
ZDan (03-07-2021)
Old 03-08-2021, 07:24 AM   #37
gravitylover
In some states you'd get dinged pretty good on insurance rates for a two seater. The shorter wheelbase on a car this light would probably make the ride suck for a daily driver. I agree with the F Type sentiment, that car is so damned hot...
The Following User Says Thank You to gravitylover For This Useful Post:
Dadhawk (03-08-2021)
Old 03-08-2021, 09:00 AM   #38
Did great job on photochopped. But it won't be THAT short in the rear. iirc when I was talking with Tada-san, about what if kinda thing and he said if 86 was 2 seater, it would of been fraction shorter in front & rear.
With the understanding that this whole topic is based upon theories and wishes there was probably no way they could make the rear much shorter even if it was only a two seater. North American crash standards have a minimum crumple distance for both front and rear which can be difficult to meet. Sure they can pull it off with the right platform but there are probably very good reasons that this platform just couldn't do it without a full redesign. A full new design will just mean compromises elsewhere which would end up with a car that has totally difference characteristics than the 2+2. The changes could be good or they could be really really bad.
Dadhawk (03-08-2021), ichitaka05 (03-08-2021)
Old 03-08-2021, 09:51 AM   #39
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
A full new design . . .
I think we are fortunate that Toyobaru brought the 2 + 2 chassis to market.
LimitedSlip is offline   Reply With Quote
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post:
gravitylover (03-08-2021), Tcoat (03-08-2021)
Old 03-08-2021, 10:12 AM   #40
I for one would not have bought if a two seater. The rear seats may not be great but at least they are there when needed.
Old 03-08-2021, 10:34 AM   #41
Sasquachulator
Pavement Grey
same here, i need them back seats.
Besides, if you want a 2 seater theres a bunch of alternatives.
Miata, Nissan Z, Supra (which the 2 seat FT86 more or less would be...but with a more powerful turbo engine, and more upscale interior)
Old 03-08-2021, 10:39 AM   #42
The Supra is a good example of how the car would be about the same size even with just two seats.
Dadhawk (03-08-2021), nikitopo (03-08-2021), Ohio Enthusiast (03-08-2021)
Is The Crossover The New Sports Car? FT86 Vs. BMW X7 M50i Vs. Supra & 8 rennlistuser3 FR-S / BRZ vs.... 45 08-08-2020 11:22 AM
[||•]=(FT86)=[•||] SWITCHBACKS | LED DOMELIGHT | MORE LEDS --> [||•]=(FT86)=[•||] 86SPEED Interior Parts (Incl. Lighting) 10 10-25-2018 03:13 PM
Evasive FT86 Service & Maintenance Thread Discount Labor for FT86 Members Evasive Motorsports Southern California 423 10-01-2018 12:49 PM
Has the FT86 changed the sports car industry? husker741 Scion FR-S / Toyota 86 GT86 General Forum 112 10-24-2013 09:15 AM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 03:22 AM
