Southern California SoCal
Old 01-14-2013, 08:45 PM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Evasive FT86 Service & Maintenance Thread Discount Labor for FT86 Members
Evasive Motorsports would like to give another introduction of our service department to both current and new members of the FR-S or BRZ community. Most of FR-S and BRZ members are aware of service we provide but to those who aren't, we provided a list our most common services. Our knowledge and experience allowed us to be capable of diagnosing and rebuilding everything from engine/transmission rebuilds to diagnosing suspension and chassis issues. We also stock full inventory of Motul, Amsoil, along with Project Mu and Endless brake fluids. Established in 2002, Evasive Motorsports has been bringing the best quality parts and customer service in the aftermarket industry for over a decade. Evasive Motorsports is a HKS Pro dealer (only 6 in the nation), Master EcuTek dealer, and has been building race cars since its inception. Evasive Motorsports has tackled Pike's Peak International Hill Climb in its Scion-backed FR-S, the fastest supercharged FR-S to complete the race to date. Evasive also has a Subaru BRZ which has broken the 2min mark at Buttonwillow Raceway, being the first daily driven NA ZN6 car to do so. Evasive Motorsports' services include installation & maintenance, race alignment, fabrication, dyno tuning. It is truly your one stop shop for all your FR-S and BRZ needs.
Our facility operates Monday-Friday 9am-6pm. Feel free to PM or call us at (626) 336-3400 if there are questions or services you would like to have done that may not be listed below. (Note: Pricing below is for service only and do not include parts unless specified.)
Basic Service & Maintenance
Oil Change - $95.00 (includes Motul 8100 ECO 0W-20 or Amsoil and genuine Subaru oil filter)
Spark Plugs -$320.00 (Plugs not included) (+$110 HKS Super Fire Plugs)
Transmission - $70.00 (Amsoil 75w90 or 75w90 Gear 300)
Differential - $60.00 (Motul Gear 300 or Amsoil Severe Gear 75w90)
Coolant Flush -$125 (Toyota 50/50)
Brake Bleed - $125.00 (includes Motul RBF600)
Brake Lines Install - $250
Pad Install - $70 Front $70 Rear $100 for both
Brakes & Rotor Install - $130.00
Intake - $50.00-$100 Depends on Intake System (starting, intakes that require bumper removal is extra; Call/PM)
Exhaust - $75.00
Over Pipe - $50
Header - $125.00 (header wrap extra)
Pulley Install - $125 Crank / $200 Full Pulley Kit
Clutch - $500 (fluids not included or clutch)
15k/45k Service - $240.00 (includes Motul 8100, Subaru oil filter/MTF, Diff (Motul Gear 300), inspect brakes/belts/fluids/air pressure/joints/seals - top off all fluids)
30k/60k - $430.00 (includes genuine Toyota coolant/air filter/accessory belts in addition to 15k Service items listed above)
Major Service
TSB S-SB-0033-13 $1700
Hard Start, Rough Idle, Camshaft Sensor or Misfire DTCs
TSB S-SB-0033-13 Toyota Chain Cover Assembly TOY-SU003-04572 + Oil Change + Coolant Flush
DI injector Swap $1000
Plus Parts
Suspension & Drivetrain Components
Alignment - $90.00 (any spec)
(+$25 if you have camber arms)
Corner Balance - $250 (includes 4-wheel alignment)
Coilover - $180.00 for pre-assemble coilovers with top hat (coilovers w/o top hats - i.e. KW / JRZ / Motons (+$20)
Springs/Shocks - $200.00
Sway Bar - $60.00/each
Differential Collars - $100.00
Rear Lower Control Arm - $125.00 (Cusco and Stance)
(SPC $180 Need to press bushing out)
Front Roll Center - $200 (need to press bushing out)
Under Brace - $50.00
Final Drive - $900.00 (additional $150.00 if diff needs to be taken off car) (fluids not included)
Aftermarket LSD - $375.00 (additional $150.00 if diff needs to be taken off car) (fluids not included)
Final Drive + LSD - $1350.00 (fluids not included)
Bushing Kit replacement - PM/Call
Exterior & Aero Service
Tire Mount/Balance - $20.00/wheel
Tire Dismount - $5.00/wheel
TPMS - additional $10.00/wheel
Fender Roll - $75.00/corner
Roll Bar install - $800 (Cusco)
Full Cage install - $1200
Steering Wheel/Hub install - $125
GT Wing install - $125.00
EVS Custom Front Splitter - PM/Call
EVS Custom Flat Belly - PM/Call
EVS Custom Roll Cage - PM/Call
Supercharger Kits or Turbo Kits Install - PM/Call Starting at $600-$1000 Depends on which kit.
(Also buyers get a discount on install if kit is bought from us)
Fuel system Install - $300
-Injectors and Fuel Pump
Dyno Pull - 3 pulls - $100
Address: - 11829 Hamden Place, Santa Fe Springs, CA 90670 (main intersections Pioneer/Telegraph)
Web: - www.evasivemotorsports.com
Blog: - blog.evasivemotorsports.com
Evasive Service Calender
Hours of Operation: Monday-Friday 9am-6pm
Contact: (626) 336-3400
Email: joshua@evasivemotorsports.com or randy@evasivemotorsports.com
Evasive Motorsports is offline   Reply With Quote
Old 01-14-2013, 10:27 PM   #2
Gen
Drives: Scion FR-S
Pretty decent prices...
Gen is offline   Reply With Quote
Old 01-14-2013, 10:35 PM   #3
sf86
sf86's Avatar
Drives: Red Scion FRS AT
Wish you were in San Francisco or around the bay area.
Sent from my HTC One XL using Tapatalk 2
sf86 is offline   Reply With Quote
Old 01-15-2013, 01:15 PM   #4
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
Wow I didn't know you guys did all this too.. wtf... better late than never. +1 for a great shop, been there before and would be very pleased to keep doing business.
Jared0934 is offline   Reply With Quote
Old 01-15-2013, 01:53 PM   #5
WWEVOX
Drives: White Lancer Evolution X
I think I'll be stopping by from time to time.
I imagine a Vortech supercharger won't be too difficult.
WWEVOX is offline   Reply With Quote
Old 01-15-2013, 02:59 PM   #6
Evasive Motorsports
Not a problem
-Randy
Old 01-15-2013, 03:02 PM   #7
Evasive Motorsports
Not a problem Jared how is that exhaust coming along? Sound really good when it left.
-Randy
Old 01-15-2013, 03:03 PM   #8
Evasive Motorsports
We have customer that drive down all the time! If you are down here stop on by.
-Randy
Old 01-16-2013, 12:07 AM   #9
jflogerzi
jflogerzi's Avatar
will you guys be open this comming monday with it being a holiday? If so I need some goodies installed and your shop looks great. Plus I really would love seeing your car in person!
Old 01-16-2013, 12:55 AM   #10
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
Looks pretty good!!!
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 01-16-2013, 02:44 PM   #11
Evasive Motorsports
Yes we will be open! Come on by!
-Randy
Old 01-16-2013, 03:08 PM   #12
TRD_86
Drives: 2013 86 white
I recommend Evasive need to have Saturday schedule because that is the day many customer will come for service or leave the car there for many services. As an 86 car owner I really want to see you guys on Saturday to do serveral upgrades aftermarket but you guys close while many other autoshops all open on Saturday.
TRD_86 is offline   Reply With Quote
Old 01-16-2013, 03:17 PM   #13
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Beautiful shop
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 01-16-2013, 03:18 PM   #14
Evasive Motorsports
Give us a call 626-336-3400 maybe we can work something out. You also can drop off your car on a weekday after work and pick it up the that day.
-Randy
evasive, evasive motorsports, service, theonlyrealracecarshop
This is a call to all FT86 Members TSwiftgavemecrabs Off-Topic Lounge [WARNING: NO POLITICS] 16 03-27-2015 07:57 PM
a idea for the FT86 club members oso_25 Exterior Parts - The Rest 1 06-22-2012 10:49 PM
FT86/FR-S Aero Thread WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 05-16-2011 01:42 AM
