| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Toyota 86
Fitment help
I have Eibach sport-line springs coming. And I want to get a new wheel setup soon. I’m looking at Enkei TS-7 or TSR-X in 18x8 +45 or 18x8.5 +45. I will most likely get some 10 mm spacers to get to that +35 that I like. But can I run a tire 225-245/40/18 without problems ? I like the 18 wheels but want a 40 wall bc I like the look better. And these wheels are only in 18s.
#2 |
Drives: '23 BRZ
225/40-18, 245/35-18. Those have sidewall heights of 225*.4 = 90mm, 245*.35 = 86mm. 245/40-18 is too tall, 245*.4 = 98mm, 25.7" diameter vs. 24.7" stock.
#3 |
Drives: Toyota 86
#4 |
Drives: '23 BRZ
235/40-18 still a lot taller than stock, I'd stick with 225/40-18
#5 |
Drives: 17 Asphalt 86
You'll want 2.5" ARP extended studs for 10mm spacer.
You may already know that but didn't mention it in your post. |
#6 |
Drives: Toyota 86
#7 |
Steve Bodalenko
Drives: Toyota 86 GTS
So I need some clarification on what size wheels can be fitted with standard LCA’s. I was under the belief that anything over 8.5 +38 required adjustable for camber LCA’s.
#8 |
Drives: '23 BRZ
#9 |
Steve Bodalenko
#10 |
Drives: '23 BRZ
None whatsoever.
Stock LCAs no problem in back, up front I'm running camber plates to get ~3 degrees camber. You might want camber bolts at least up front. Last edited by ZDan; 02-26-2021 at 09:30 AM. |
#11 | |
Drives: '16 BRZ Limited
Fronts are a close fit. But as far as tires go, I've done 235/40/18 Hankook Ventus V12 evo2, 255/35/18 Firestone Firehawk Indy500, and now on 245/35/18 Michelin Pilot Sport 4 S which is most similar to oem tire diameter. No rub at all. |
| FRS Fitment help !! | FRS Megan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-03-2020 10:17 PM |
| How's the fitment of 1320's dual res fp fitment on AT | aznchris | Engine, Exhaust, Transmission | 0 | 04-16-2019 07:02 AM |
| Looking for some help on fitment | AnthonyArcaro | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-22-2018 08:28 PM |
| TRD Kit fitment | Ds3ire | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 03-16-2016 04:11 PM |
