Old 02-14-2021, 11:24 AM   #1
Lopeskii
Lopeskii's Avatar
Drives: Toyota 86
Fitment help
I have Eibach sport-line springs coming. And I want to get a new wheel setup soon. I’m looking at Enkei TS-7 or TSR-X in 18x8 +45 or 18x8.5 +45. I will most likely get some 10 mm spacers to get to that +35 that I like. But can I run a tire 225-245/40/18 without problems ? I like the 18 wheels but want a 40 wall bc I like the look better. And these wheels are only in 18s.
Lopeskii is offline   Reply With Quote
Old 02-14-2021, 11:42 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
225/40-18, 245/35-18. Those have sidewall heights of 225*.4 = 90mm, 245*.35 = 86mm. 245/40-18 is too tall, 245*.4 = 98mm, 25.7" diameter vs. 24.7" stock.
Old 02-14-2021, 12:08 PM   #3
Lopeskii
Lopeskii's Avatar
Drives: Toyota 86
So 225/40-18 can fit. Will 235/40-18 fit or stick with 225?
Old 02-14-2021, 12:25 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
235/40-18 still a lot taller than stock, I'd stick with 225/40-18
Old 02-14-2021, 12:28 PM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You'll want 2.5" ARP extended studs for 10mm spacer.
You may already know that but didn't mention it in your post.
Old 02-14-2021, 12:43 PM   #6
Lopeskii
Lopeskii's Avatar
Drives: Toyota 86
Thanks, I knew with the spacers I would have to get longer studs, just haven’t looked into the size yet
Old 02-25-2021, 03:11 AM   #7
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
So I need some clarification on what size wheels can be fitted with standard LCA’s. I was under the belief that anything over 8.5 +38 required adjustable for camber LCA’s.
Bodalenko is offline   Reply With Quote
Old 02-25-2021, 10:18 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'm running 245/40-17 on 17x9 +35, 1.2" lowered on springs, factory LCAs.
Old 02-26-2021, 02:56 AM   #9
Bodalenko
Steve Bodalenko
No rubbing? No fouling?
Old 02-26-2021, 06:21 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
None whatsoever.
Stock LCAs no problem in back, up front I'm running camber plates to get ~3 degrees camber. You might want camber bolts at least up front.
Old 03-04-2021, 01:38 AM   #11
meWant
Drives: '16 BRZ Limited
Went from previous wheels (18x8.5 +35) to new wheels (18x9.5 +38) with just springs and stock LCA.
Fronts are a close fit. But as far as tires go, I've done 235/40/18 Hankook Ventus V12 evo2, 255/35/18 Firestone Firehawk Indy500, and now on 245/35/18 Michelin Pilot Sport 4 S which is most similar to oem tire diameter. No rub at all.
meWant is offline   Reply With Quote
FRS Fitment help !! FRS Megan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-03-2020 09:17 PM
How's the fitment of 1320's dual res fp fitment on AT aznchris Engine, Exhaust, Transmission 0 04-16-2019 06:02 AM
Looking for some help on fitment AnthonyArcaro Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-22-2018 07:28 PM
TRD Kit fitment Ds3ire Cosmetic Modification (Interior/Exterior/Lighting) 20 03-16-2016 03:11 PM
