Old 02-08-2021, 03:12 PM   #1
vin08
275/1000
Drives: 2016 RS2 auto
Delicious tune OFT flex fuel kit
I just moved to a house that have a E85 station here in SoCal so finally going to get the flex fuel. but OFT stop selling their kit so had to get a Delicious kit for my 2016 FRS. Has anyone gotten this kit and installed it and can share instruction?
vin08 is offline   Reply With Quote
Old 02-08-2021, 04:14 PM   #2
Uncle86
Uncle86's Avatar
Drives: 2013 Fr-s
Sent from my SM-G781U using Tapatalk
Uncle86 is offline   Reply With Quote
Old 02-08-2021, 04:35 PM   #3
CSG Mike
CSG Mike's Avatar
https://www.delicioustuning.com/info
CSG Mike is online now   Reply With Quote
Old 02-08-2021, 06:15 PM   #4
vin08
275/1000
I have that link already. but it's for ECUTECH version. I heard i need to hook up evap sensor if i want to run OFT tune. Also my unit came with a red wire and the instruction doesn't show what to do it that wire.
Old 02-08-2021, 07:13 PM   #5
CSG Mike
CSG Mike's Avatar
There is no EVAP version.
Old 02-09-2021, 06:28 AM   #6
stacyu18
Drives: 2014 subaru brz
I installed my delicious tune e85 kit and dont recall any red wire just 2 plugs one to the second 02 sensor and one to the e85 kit but there again im not doing the oft
stacyu18 is offline   Reply With Quote
Old 02-09-2021, 11:09 PM   #7
steve99
Drives: FT86
delicious have this one that has flying lead for evap connection
https://www.delicioustuning.com/OFT-FlexFuel
Old 02-09-2021, 11:15 PM   #8
steve99
Drives: FT86
ive tuned a few guys on oft flex using the deliceous kit
or other zetronics flex kits .
you can convert the rear 02 kits to evap jist cut off the rear 02 plug source 12v via a fuse tap source a ground\earth and reroute the sensor wire to evap on ecu Connector A34 pin 20 as per the oft fftek flex kit instructions
also Xero limits tuning make a full plug and play evap flex kit
https://www.xero-limit.com/xero-limi...gt86-evap.html
Note oft flex tune only support pre facelift cars after 2017 you need ecutek can do that as well
Old 02-10-2021, 06:58 PM   #9
vin08
275/1000
Is this what the red flying wire is for?
For OFT, this kit features a flying lead wire that is to be routed through the right side firewall. The wire inputs ethanol percentage into the ECU via the CPC input wire located at the ECU harness this can be tapped via the included wire tap.
know where i plug into on the ECU side?
Old 02-11-2021, 05:13 AM   #10
steve99
Drives: FT86
goes to connector A34 Pin 20 on ecu that's evap input see the oft fftec flex kit install guide
FS: Delicious tuning flex fuel black stainless steel braided fuel lines iceblaze Southern California 0 09-12-2019 03:36 PM
Delicious Flex Fuel Mk1+ shaynek Engine, Exhaust, Bolt-Ons 3 01-14-2019 07:42 PM
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-25-2016 11:06 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
