| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Persona Non Grata
Drives: '15 BRZ (WRB)
Does Anybody Ever:
Follow the service manual and use new bolts and nuts where it specifies?
Slow is smooth, and smooth is fast
#2 |
Yes but not always. Depends on the application.
#3 |
ProCrastinationConsultant
depends entirely on whether i planned the job out in advance, or if new bolts can be delivered by tomorrow.
i've always re-used the copper drain plug crush washer...
| The Following User Says Thank You to soundman98 For This Useful Post: | Ohio Enthusiast (02-06-2021) |
#4 |
Drives: BRZ 2018
#5 |
30 minute maintenance
Drives: My18 wrxsti
Not on head bolts or snapped wheel studs
| The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | Capt Spaulding (02-07-2021), soundman98 (02-07-2021) |
#6 |
Persona Non Grata
I've seen a number of how-tos on a variety of mod procedures and I can't think of any of them that mentioned the fastener replacement issue. I swapped out my stabilizer bar bushings (front and rear) recently. At both ends, the FSM specifies new fasteners. The front subassembly uses eight 10mm (shank diameter) bolts that get torqued to 44 lb/ft, That seemed really low considering the number and size of the bolts. I reused. Similar with rears.
Over the years, I've generally seen the bolt replacement requirements in torque-to-yield situations. I've religiously applied the replacement rule in those cases. Other places like brake caliper bolts on roadracing motorcycles where the calipers are coming off and going on like neon signs - generally not. Subie seems to take the approach that "if you turn the bolt or nut, replace it." I chalk it up to litigation paranoia, but ... Thanks for the input.
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#7 |
Sounds like you have ample experience to make appropriate decisions. You gots dis.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Capt Spaulding (02-07-2021) |
#8 | |
".(sorry folks, I told Bubba to stay away from my computer).
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (02-08-2021) |
#9 |
Famous Potatoes
Drives: '15 ultramarine
Yes and no.
Depends on the situation |
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (02-08-2021) |
#10 |
| The Following User Says Thank You to humfrz For This Useful Post: | gravitylover (02-10-2021) |
#13 |
Drives: 20 BRZ
Yes and especially under warranty.
#14 |
Yes, almost always.
