Old 02-06-2021, 03:19 PM   #15
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Originally Posted by Muskoka800 View Post
I've changed to the longer front lugs without issues.
When attempting the rears I found an issue not apparent in the video above.
After removing the four hub bolts I was unable to pull the hub away from the upright. It seems the bearing is bonded in place, likely by rust.
Does anyone have a non-destructive technique to drive the bearing out?
Perhaps an air chisel from the back on the slightly loosened bolts might break it loose??? Not much room in there to swing a BFH.
Rent a slide hammer. There are videos on YouTube that will show you how to do it.
Also try hitting the outside perimeter with a punch/hammer to see if you can break/shock the rust bond up a little.
Joon525 is offline   Reply With Quote
Old 02-06-2021, 03:37 PM   #16
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Air chisel is probably your best bet. Even then be prepared for a fight.
I know a few who tried other methods and waste an entire weekend and never get it off.
Old 02-06-2021, 04:29 PM   #17
whataboutbob
AutoX-10/10ths every run
Remove the wheel speed sensor before removing the hubs to avoid damaging the sensor. Speaking from experience.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Ultramaroon (02-06-2021)
Old 02-06-2021, 05:01 PM   #18
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Thanks all.
Yes, did remove the speed sensor first.
I did try attacking it with hammer and punch to no effect.
Leaning toward the air chisel solution.
Fortunately the stock lugs are adequate length-wise out back. Added spacers in the front dictated longer lugs there.
Will take another run at them in the spring. Car in hibernation/winter mode currently.
Muskoka800 is offline   Reply With Quote
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 08:20 PM
Easy REAR Wheel Stud replacement - Shade Tree Mechanic Style Dake DIY (Do-It-Yourself) Guides 24 10-07-2020 11:56 AM
Just another wheel stud replacement video. mhightower FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 04-26-2017 03:01 PM
South Bay Wheel Stud Replacement? HachiRo Northern California 4 02-04-2016 04:56 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 01:58 PM
