Old 01-21-2021, 04:37 PM   #43
CSG Mike
CSG Mike's Avatar
There's now a single disc CSG clutch, that includes an upgraded throwout bearing (significantly larger than stock) and shift fork.
https://www.counterspacegarage.com/c...ch-system-fa20
It's the same upgrade used for the high capacity twin disc.
MJones_RB (01-26-2021)
Old 01-21-2021, 04:50 PM   #44
Pat
Pat's Avatar
Drives: 2023 BRZ
Well this is interesting. You've spoken well of the GReddy kit in the past. Can you tell me, someone that doesn't know much about clutches, the difference between this OS Giken kit and the GReddy one?
Old 01-21-2021, 08:35 PM   #45
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Could use some advice here. Since I'm already gonna have to drop the transmission to replace the TOB, should I go ahead and upgrade the clutch and flywheel? My FRS does dual duty as a daily driver and autocross car.
Kind of considering putting in the Verus forged fork, Exedy Stage 2 clutch and racing flywheel. Would that setup still be tolerable for daily driving? The OEM clutch feels really light to me, so I don't think a little bit stiffer would bother me.
Power wise, I normally daily on the OFT Stage 2 E85 tune, except for SCCA events. Might possibly go forced induction in the future though. Nothing too crazy, maybe like 300whp at the very max.
smg1138 is offline   Reply With Quote
Old 01-21-2021, 11:30 PM   #46
DarkSunrise
DarkSunrise's Avatar
Originally Posted by TRAKRAVN View Post
My case was a "new" bearing, I'm not sure if it was updated or not with the forged clutch fork. and the solution was changing the transmission input housing.
Yeah I also changed the snout to be safe, but surprisingly my old one looked to be in decent condition. I think a mild clean and polish would have cleaned it up nearly like new.
I upgraded the clutch/flywheel when my TOB died. No regrets. Great excuse to upgrade. Can't speak to the Exedy Stage 2 clutch, but I've got the Exedy Stage 1 with 12.7 lbs flywheel and love the combination. The quicker rev matches with the LWFW are great, as is the faster engagement of the clutch.
For daily driving, the clutch pedal is slightly heavier and it engages a bit quicker, but still easy to drive. I think the key is to avoid pairing a LWFW with an aggressive clutch. I could see that quickly becoming annoying because of the lack of flywheel weight and quick engagement of the clutch.
I've noticed recently a bit of rattling with the a/c engaged (flywheel chatter, I believe), but it doesn't bother me. Also a bit of drone on decel around 3000 rpm, but that is probably made worse from my diff cradle inserts.
Consider a Verus forged clutch fork as well.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
smg1138 (01-21-2021)
Old 01-22-2021, 12:53 PM   #47
smg1138
smg1138's Avatar
If you are changing your throw out bearing I would also recommend to change the transmission input shaft housing. I've seen it where the bearing is new but because of the heat the plastic part in the center of the bearing can catch on the outer cylinder of the housing even when greased up. I believe part is about $100 through the dealer.
This is the first I’ve heard of this. Do you know the part number for that?
Old 01-22-2021, 05:16 PM   #48
CSG Mike
CSG Mike's Avatar
I have a GReddy turbo, and an OS Giken clutch
Pat (01-22-2021)
Old 01-22-2021, 05:17 PM   #49
CSG Mike
CSG Mike's Avatar
You're a perfect candidate for the CSG Single disc clutch, since it covers all your bases, while giving you a nominally heavier pedal that will also give you much more engagement feedback.
The floating basket design will make a "rattle" when you're stepping on the clutch pedal, at idle, but most people don't mind it. While a different type of noise, the concept is similar to a Ducati clutch.
smg1138 (01-22-2021)
Old 01-22-2021, 05:53 PM   #50
Jdmjunkie
Drives: Scion FR-S 10 Series
I love my OS Giken clutch, some of the best money I have spent on the car! The OSG rattle is a noise I have come to love! Next up is their diff!
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
CSG Mike (01-22-2021)
Old 01-22-2021, 06:12 PM   #51
CSG Mike
CSG Mike's Avatar
In those rare instances you run into another car with the OSG sound, you'll look at each other and
IYKYK
Jdmjunkie (01-22-2021)
Old 01-22-2021, 06:12 PM   #52
smg1138
smg1138's Avatar
@CSG Mike Does that kit use the stock flywheel or a lighter one? Just found out SCCA rules don’t allow for a lighter flywheel in STX class.
Old 01-22-2021, 06:21 PM   #53
CSG Mike
CSG Mike's Avatar
It's a complete conversion.
I don't think it'll fly in STX class... but a custom one could be made for you to be the same weight as OEM...
Old 01-22-2021, 08:32 PM   #54
Jdmjunkie
So in theory if I did the Kpower swap would OSG be able to make me a custom flywheel to fit the swap?
Old 01-22-2021, 08:35 PM   #55
CSG Mike
CSG Mike's Avatar
yes, but everything else would need to be specified to figure out the stack height, configuration, etc.
Alternatively, it could be JUST the clutch, and you're on your own to figure out the rest.
Old 01-23-2021, 12:18 PM   #56
TRAKRAVN
Drives: 2015 Scion FRS - Raven
https://parts.villagetoyota.com/p/To...U00303853.html
TRAKRAVN is offline   Reply With Quote
Hip replacement and the BRZ g e BRZ First-Gen (2012+) — General Topics 10 07-06-2018 06:12 AM
Replacement Key 86 South Africa AFRICA 7 09-19-2016 03:58 PM
Replacement fun? Mooseknuckle44 Scion FR-S / Toyota 86 GT86 General Forum 44 05-01-2014 11:46 AM
TPSM replacement nabil_frs CANADA 4 04-27-2013 11:58 AM
TPSM replacement nabil_frs Issues | Warranty | Recalls / TSB 2 04-26-2013 09:57 PM
